Chaz54
Starter Change-Out
Chaz54
I have a 1988 520H Wheel Horse that I’m trying to change out the starter. How do you get it out? Do I need to remove the flywheel?
953 nut
This Onan Service Manual from our Banuals section will give you all the guidance you should need.
Chaz54
The description is just a basic description that is not a complete description of how the starter can be removed from the engine. Anyone who has ever changed their starter is who I’d like to know more about how they did this. It seems like I’m going to either remove the flywheel or pull the entire engine off the engine mounting plate.
squonk
I think I heard somewhere that they had to lift the engine.
953 nut
According to the Service Manual I attached to my previous post it seems rather straight forward. You probably should remove the hood hinge assumedly fitst.
