FLtractor
856 Crankshaft pulley questions
FLtractor
Evening,
Just making sure.. the proper factory sized 856 crankshaft pulleys for transmission and belt drive off crankshaft.. both are 4 inch diameter with 1 inch bore? What size woodruff key needed?
ebinmaine
The engine pulley is a 2" outer diameter.
The transmission pulley I believe is 4" but the internal bore is much smaller.
Either 5/8 or 3/4 inch.
What prompts the question?
FLtractor
Evening Eric, I just went outside with a tape measure to double verify. Measuring across lengthway thru the center of the crankshaft
picture attached of pulley measured:
Top 2 pulley on engine crankshaft= 2 1/2 inch
     Middle and bottom = 3 inch each.
Ask since I was told my flywheel belt is wrong being fabric.. can cause glazing with the slipping and should be the ribbed belt on one side.. well after looking at all my belts they are all fabric and all very old need to get new ones. . should I change them all too ribbed one side? Pulleys seems to be glazed due to this and should be replaced at this time too.. easier all at once.
ebinmaine
Are you talking about the green transmission drive belt?
953 nut
You are looking at the wrong side of the engine.. The Starter / generator belt should be a 3/8" wide rubber edge cogged belt 3L-32  NAPA # 25-7315
FLtractor
Already have new S/G cogged belt I need… Need to replace both my transmission and that deck drive belt connected to the 3 pulleys. Need to know are both the transmission and 3 pulleys connected deck drive belt need to be cogged belts too?
Edited by FLtractor
FLtractor
Yes I know.. I have the new cogged belt already.. do the transmission belt and deck drive 3 pulley connected belt need to be cogged belts too instead of fabric? Have item numbers for those two by chance?
ebinmaine
The flywheel to generator belt should not be fabric.
The transmission belt MUST BE FABRIC COATED.
The green belt is fabric coated and NEEDS to be able to slip.
It is literally the clutch of the machine.
pfrederi
The mower deck belts (3) can be fabric covered as also the transmission drive belt.    Honestly  I have units running with belts looking a lot worse than yours and they work just fine.
ebinmaine
IMHO that's not necessary as long as the proper length RUBBER belt is used.
FLtractor
Ahhh so 1/2x70 transmission belt must be fabric due to how it slacks everytime clutch depressed.. makes sense. Thanks Eric
FLtractor
Oh ok. Good to know. Do you happy to have a parts # or what size belt I need for the mower deck 3 belt if I were to eventually replace it?
FLtractor
Wouldn’t think people would use other materials such as cloth?
pfrederi
instead of surfing Facebook check out the manual section here
  • Haha 1
FLtractor
Thanks.
