FLtractor 249 #1 Posted 2 hours ago Evening, Just making sure.. the proper factory sized 856 crankshaft pulleys for transmission and belt drive off crankshaft.. both are 4 inch diameter with 1 inch bore? What size woodruff key needed? Share this post Link to post Share on other sites
ebinmaine 81,126 #2 Posted 2 hours ago The engine pulley is a 2" outer diameter. The transmission pulley I believe is 4" but the internal bore is much smaller. Either 5/8 or 3/4 inch. What prompts the question? Share this post Link to post Share on other sites
FLtractor 249 #3 Posted 1 hour ago 1 hour ago, ebinmaine said: The engine pulley is a 2" outer diameter. The transmission pulley I believe is 4" but the internal bore is much smaller. Either 5/8 or 3/4 inch. What prompts the question? Evening Eric, I just went outside with a tape measure to double verify. Measuring across lengthway thru the center of the crankshaft picture attached of pulley measured: Top 2 pulley on engine crankshaft= 2 1/2 inch Middle and bottom = 3 inch each. Ask since I was told my flywheel belt is wrong being fabric.. can cause glazing with the slipping and should be the ribbed belt on one side.. well after looking at all my belts they are all fabric and all very old need to get new ones. . should I change them all too ribbed one side? Pulleys seems to be glazed due to this and should be replaced at this time too.. easier all at once. Share this post Link to post Share on other sites
ebinmaine 81,126 #4 Posted 58 minutes ago 11 minutes ago, FLtractor said: Ask since I was told my flywheel belt is wrong being fabric. Are you talking about the green transmission drive belt? Share this post Link to post Share on other sites
953 nut 70,290 #5 Posted 53 minutes ago You are looking at the wrong side of the engine.. The Starter / generator belt should be a 3/8" wide rubber edge cogged belt 3L-32 NAPA # 25-7315 Share this post Link to post Share on other sites
FLtractor 249 #6 Posted 24 minutes ago (edited) 35 minutes ago, ebinmaine said: Are you talking about the green transmission drive belt? Already have new S/G cogged belt I need… Need to replace both my transmission and that deck drive belt connected to the 3 pulleys. Need to know are both the transmission and 3 pulleys connected deck drive belt need to be cogged belts too? Edited 22 minutes ago by FLtractor Share this post Link to post Share on other sites
FLtractor 249 #7 Posted 23 minutes ago 28 minutes ago, 953 nut said: You are looking at the wrong side of the engine.. The Starter / generator belt should be a 3/8" wide rubber edge cogged belt 3L-32 NAPA # 25-7315 Yes I know.. I have the new cogged belt already.. do the transmission belt and deck drive 3 pulley connected belt need to be cogged belts too instead of fabric? Have item numbers for those two by chance? Share this post Link to post Share on other sites
ebinmaine 81,126 #8 Posted 20 minutes ago 48 minutes ago, FLtractor said: Ask since I was told my flywheel belt is wrong being fabric.. can cause glazing with the slipping and should be the ribbed belt on one side. The flywheel to generator belt should not be fabric. The transmission belt MUST BE FABRIC COATED. The green belt is fabric coated and NEEDS to be able to slip. It is literally the clutch of the machine. 1 Share this post Link to post Share on other sites
pfrederi 21,294 #9 Posted 19 minutes ago The mower deck belts (3) can be fabric covered as also the transmission drive belt. Honestly I have units running with belts looking a lot worse than yours and they work just fine. 1 1 Share this post Link to post Share on other sites
ebinmaine 81,126 #10 Posted 19 minutes ago 51 minutes ago, FLtractor said: should be the ribbed belt IMHO that's not necessary as long as the proper length RUBBER belt is used. 1 Share this post Link to post Share on other sites
FLtractor 249 #11 Posted 9 minutes ago 10 minutes ago, ebinmaine said: The flywheel to generator belt should not be fabric. The transmission belt MUST BE FABRIC COATED. The green belt is fabric coated and NEEDS to be able to slip. It is literally the clutch of the machine. Ahhh so 1/2x70 transmission belt must be fabric due to how it slacks everytime clutch depressed.. makes sense. Thanks Eric Share this post Link to post Share on other sites
FLtractor 249 #12 Posted 8 minutes ago 10 minutes ago, pfrederi said: The mower deck belts (3) can be fabric covered as also the transmission drive belt. Honestly I have units running with belts looking a lot worse than yours and they work just fine. Oh ok. Good to know. Do you happy to have a parts # or what size belt I need for the mower deck 3 belt if I were to eventually replace it? Share this post Link to post Share on other sites
FLtractor 249 #13 Posted 8 minutes ago 10 minutes ago, ebinmaine said: IMHO that's not necessary as long as the proper length RUBBER belt is used. Wouldn’t think people would use other materials such as cloth? Share this post Link to post Share on other sites
