mjp1853@gmail.com 0 #1 Posted 23 hours ago Hey All, Just bought a 315-8 after not being able to find a 314-8 with a Kohler CH14. I didn't realize that they have an electric PTO and am concerned about the reliability and replacement cost of them. I was able to buy it right less than 400 hours for $650, but the paint isn't the greatest because of how it was stored. In any event, I want to convert back to a manual PTO. Has anyone ever done this? I was able to find an older 312 / 1992 / K804 parts tractor for $250....I think I can sell the engine or deck and break even. From my research, it looks like both have 1" crankshafts extending around 3". Am I correct in thinking, I can use the linkage and side sheet metal from the 312 to convert to a manual setup like on the later(1999-2001) 314s? The only other consideration would be to unwire the electric PTO switch? Does it have to be shorted out like the seat and mow in reverse or left in an open position? Thanks for your input....I really appreciated it. Mark Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,532 #2 Posted 21 hours ago Welcome to Red Square The pto clutch is electric because the CH engine is not capable of handling the thrust pressure of a manual pto. 2 1 Share this post Link to post Share on other sites
pfrederi 21,292 #3 Posted 20 hours ago Wheel horse used an external thrust bearing on some B&S powered WHs. it may be possible to do something similar to your CH engine Share this post Link to post Share on other sites
ri702bill 13,312 #4 Posted 13 hours ago I for one, am not a fan of the elecrtomagnetic clutch. From the factory, the engagement is a sudden "all or nothing" action; you cannot ease into it like you can do with a manual. BUT - some folks have added a "soft start" device to soften the engagement. From my own experience with commercial EM clutches, that soft start MAY shorten the life of the clutch, due to the internal workings of the clutch. 1 Share this post Link to post Share on other sites
Racinbob 13,282 #5 Posted 13 hours ago to The guys have it covered on the mechanical issues and as far as electrical you would just unplug it, no jumper. I have a 2005 with the Command and love the engine but dislike the electric clutch. I minimize the jolt by only engaging at lower RPM's. I did read about Paul's idea of adding the bearing but decided to not try it. You're right on the physical part of it being pretty simple. GDI does make a simple soft start but I've never seen one in action. The videos are cool though. 1 Share this post Link to post Share on other sites
Handy Don 17,666 #6 Posted 5 hours ago (edited) 8 hours ago, Racinbob said: GDI does make a simple soft start but I've never seen one in action I've only seen soft-start electric clutch controllers on pro-level zero turns and the guys using them that I’ve spoken with had only good things to say--no significant maintenance issues, lower horsepower needed, and very smooth starts. BUT as @ri702bill notes, clutches not intended for soft start may experience faster wear on the clutch surfaces even while soft start is reducing wear and tear on other parts (including the operator). IMHO, the soft start controller is the easiest (though not necessarily the least expensive) path to getting the 315-8 to where you want it. Edited 5 hours ago by Handy Don Share this post Link to post Share on other sites
kpinnc 19,050 #7 Posted 5 hours ago (edited) 8 hours ago, Racinbob said: GDI does make a simple soft start but I've never seen one in action. I have one on my Scag zero turn, and it has been outstanding. On my 4th year mowing 3.5 acres nearly year round with zero issues. Given that it is a 61 inch deck and 26hp, it's getting far more abuse than you'll see on a 315-8. High RPM starts make no difference. The sensor wire on it adapts to engine speed at engagement. Edited 5 hours ago by kpinnc 2 Share this post Link to post Share on other sites
