ray gershon
help with my Suburban 400
ray gershon
I installed a 5 hp Briggs on my Suburban 400 with the pulley system as shown. When i push in the brake petal to shift to another gear, all the tension is released but the belt still turns the pulley on the trans.  Is the a fix for this? Would appreciate any suggestions.
8ntruck
You need to support the bottom of the belt to keep it off of the crankshaft pulley.  Usually, there is a tab on the belt side of the belt guard that performs this function.
Wheel Horses generally need to have the belt guard installed to keep the belt off of the crankshaft pulley in order to stop the belt and be able to shift gears.
:text-welcomeconfetti:to the forum.  Lots of good folks here.  I'm pretty sure that as a group, the regular contributors here have broken and fixed just about everything on a Wheel Horse that can be broken and fixed.  Even better, they share their opinions and advice freely - sometimes it is even helpful.
sqrlgtr
You might be acle to make/use sumin like this (The tab on top of idler pulley). Main thing is belt has to stop turning for everything to work right. Pulled this pic off interweb and is not my mochine.
What are the options for a replacement clutch pulley for a ...
  • Excellent 2
parsonsponyz
Achto
:WRS:
This is what I made for my 400 with a Predator on it. Note that I added belt brakes on the engine pulley too. Not sure if they were necessary, but I had room for them with my home made belt guard.
IMG_20160213_160010659.jpg.df884e191e8e6be06b2688260ee4a4eb.jpgIMG_20160213_170529330.jpg.e327d6adca599e78ddd4edea7e910585.jpg
Edited by Achto
peter lena
@sqrlgtr  @Achto   noting those idler pulleys  , tiny bearings , a lubricant that will  stay with them / and  stand up to heat / stress , belt wear / fraying  will show you that , experimented with  lubes , and application . ideally  , rubber  side grease shield , lucas  xtra hd , green chassis grease , polyurea , 550 deg flash point , never had a  failure, REGULARLY  EXPERIMENT with REPEDITIVE FAILURES , @ achto, thought about a  short  horizontal ski  on the belt , push down ? enhance , hand off  ? only asking , nothing sarcastic , if its not bouncing , you are good .pete
Dave D.
This is good info. Gotta make a belt guard and some belt keepers when I get to that stage of the rebuild.
Dave
peter lena
@WHX??  been using  a silicone grease , on the UNDERSIDE OF THE BOOT ?  the trans irregularities' are what  causes the drag on the boot issue , grease enhanced slide , put  boot on in place , let it show you , where  it wants to be , then trap that spot with a wide tie wrap , on shifter stick , since doing that years ago , my shift  boots  are  trouble free. always experimenting with  any issue , basically , how can I stop this ? think the most interesting thing , is it always shows you the way , like a pto lever start area . a gold mine of detailing , magical difference , pete
