Sparky-(Admin) 26,631 #1 Posted 15 hours ago Any tricks to getting this brake seal out? Share this post Link to post Share on other sites
953 nut 70,107 #2 Posted 15 hours ago use an awl to make two small pilot holes 180* apart. Use two sheet metal screws tightening them alternately and the seal will back right out. 6 2 Share this post Link to post Share on other sites
Sparky-(Admin) 26,631 #3 Posted 15 hours ago False alarm! She came out with some digging/ picking and strategically spoken swear words 5 1 2 Share this post Link to post Share on other sites
Racinbob 13,259 #4 Posted 13 hours ago Puncture the metal use a small (1/8") flat blade screwdriver and tap the corner of it at an angle about centered between the case and shaft. It doesn't take much to puncture the metal and the seal will start rotating. I usually use diagonals as the hammer. 90% of the time it will start walking itself out. If it doesn't it will be loose and is easily hooked with a pick. 1 Share this post Link to post Share on other sites
peter lena 10,104 #5 Posted 10 hours ago @Sparky packing puller , https://www.ebay.com/itm/336745768885?c , lets you punch a tiny hole on seal sidewall , screw this in and pull out . also check local harbour freight , packed hundreds of tank agitator drives , regular part of CHANGE OVERS , to another product , makes quick work of seal , pete 1 1 Share this post Link to post Share on other sites
953 nut 70,107 #6 Posted 7 hours ago 3 hours ago, peter lena said: packing puller , https://www.ebay.com/itm/336745768885?c , lets you punch a tiny hole on seal sidewall Pete, that is for removing fiber packings like the ones found on steam pumps, valves and other industrial rotating shafts. Share this post Link to post Share on other sites
Handy Don 17,635 #7 Posted 6 hours ago 9 hours ago, Sparky said: strategically spoken swear words incantations and exhortations Family-ized it for ya 🫢 Share this post Link to post Share on other sites
