lorenzo 1 #1 Posted yesterday at 04:15 AM looking to replace my key switch on my electro 12 tractor [the L leg is not working, lights, clutch, lighter, etc.] the parts list show's part # 8362 it's a 5-pin switch marked B-M-S-R and L according to the wiring diagram. I can't find a 5-pin switch with those exact letters or part number. Are all 5-pin switch's the same even if the letters are different? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,524 #2 Posted yesterday at 10:52 AM No 5-pin switches are all different. Up until now the 8362 switch was still available from Toro but looks like that has ended. It was a very expensive and heavy duty switch that carried the full current required for the starter motor. What many have done in the past is replace it with a lighter duty and less expensive switch plus add a starter solenoid to carry the starter load. The heavy wires going to the switch can be replaced with 14 gauge wires and a plug in connector can be added for the new switch. Your 8362 switch has 4-key positions. A less expensive and more common 103991 switch is a 3-key position switch which should work because you have a separate light switch. A 1960's - 70's Ford solenoid is a good choice 1 2 Share this post Link to post Share on other sites
lorenzo 1 #3 Posted yesterday at 11:51 AM Thank you for the information Share this post Link to post Share on other sites
953 nut 70,114 #4 Posted yesterday at 12:34 PM 8 hours ago, lorenzo said: r. Are all 5-pin switch's the same even if the letters are different? Using the wrong switch would destroy your ignition system. As Gary told you the best way to go is replace the old switch with a 103991 and a solenoid. This diagram shows the wiring system using that switch and solenoid. Your electric PTO clutch will also be fed from the "A" terminal but should have a separate fuse. Share this post Link to post Share on other sites
ri702bill 13,278 #5 Posted yesterday at 12:43 PM 1 minute ago, 953 nut said: from the "A" terminal but should have a separate fuse. Absolutely add the fuse. When an electromagnetic cluth fails, it's one of 2 scenarios... the circuit goes "open" and nothing happens - or - the coil shorts to ground and THAT is why you need the fuse. There is quite an inrush of current - a spike - when the clutch is engaged and the rating of the fuse must be able to tolerate that... It is always better to get the high amperage load out of the keyswitch by using a solenoid - a device that was designed to do just that. The keyswitch lives longer that way. Do NOT just change to the 103991 keyswitch without adding the solenoid..... Share this post Link to post Share on other sites
evanloock 269 #6 Posted yesterday at 12:56 PM Wonder if the switch is still available from Indak? The E464A seems to be it. I am going to see if I can get any info from Indak.4 Position Key Switches (Stamped Keys) - INDAK Switches.pdf Share this post Link to post Share on other sites
lorenzo 1 #7 Posted yesterday at 12:58 PM Got it, thanks guys Share this post Link to post Share on other sites
953 nut 70,114 #8 Posted 20 hours ago 2 hours ago, evanloock said: Wonder if the switch is still available from Indak? The E464A seems to be it. I am going to see if I can get any info from Indak.4 Position Key Switches (Stamped Keys) - INDAK Switches.pdf What model and year Wheel Horse are you seeking a switch for? Once we know this information we can give a more intelligent answer. The E464A is what was used on most early '70s Wheel Horses equipped with an electric PTO. The fourth position was to connect the solenoid to the battery alone. This reduced the load on the battery by preventing the lights and PTO from being powered while starting. A 103991 switch is a three position ignition switch for magneto ignition units. Your PTO switch probably has four wires going to it, two of those wires will not allow the starter to turn over while the PTO is in the ON position so the fourth position is not needed. Share this post Link to post Share on other sites
lorenzo 1 #9 Posted 19 hours ago I have a 1970 electro 12: the switch works fine except I don't have any lights- no voltage from the switch "L" terminal, no problems starting or running. I think I'll just run a separate wire from the battery to power the lights, clutch(PTO), etc. I use this tractor as a plow tractor so I don't need the PTO to work. 1 Share this post Link to post Share on other sites
pfrederi 21,276 #10 Posted 19 hours ago An Electro depending on the year can have one of 3 different ignition systems. 2 require a magneto switch on not. Using the wrong one an a magneto breakerless system will result in expensive smoke. 1 1 Share this post Link to post Share on other sites
953 nut 70,114 #11 Posted 12 hours ago 6 hours ago, lorenzo said: I have a 1970 electro 12: the switch works fine except I don't have any lights- no voltage from the switch "L" terminal, no problems starting or running. I think I'll just run a separate wire from the battery to power the lights, clutch(PTO), etc. I use this tractor as a plow tractor so I don't need the PTO to work. That would be the lest expensive way to go, be sure to place a fuse between the battery and the light switch. 1 Share this post Link to post Share on other sites
evanloock 269 #12 Posted 9 hours ago 11 hours ago, 953 nut said: What model and year Wheel Horse are you seeking a switch for? Once we know this information we can give a more intelligent answer. The E464A is what was used on most early '70s Wheel Horses equipped with an electric PTO. The fourth position was to connect the solenoid to the battery alone. This reduced the load on the battery by preventing the lights and PTO from being powered while starting. A 103991 switch is a three position ignition switch for magneto ignition units. Your PTO switch probably has four wires going to it, two of those wires will not allow the starter to turn over while the PTO is in the ON position so the fourth position is not needed. I don't need a switch. I am just contacting Indak to see if the switch used on the magneto ignition tractors with the 2 heavy lugs that carried the current directly from the battery to the starter is the E464A switch. From the description in their catalog it appears to be. I will update the group when I hear back from them. With Toro discontinuing things it makes sense to check with the original manufacturers of the parts themselves. Share this post Link to post Share on other sites
953 nut 70,114 #13 Posted 6 minutes ago Considering the fact that thi type switch hasn't been used since 1972 and the number of remaining machines is dwindling I doubt that there is enough demand to justify making more of these switches to put on the shelf collecting dust. Share this post Link to post Share on other sites
