lorenzo 0 #1 Posted 9 hours ago looking to replace my key switch on my electro 12 tractor [the L leg is not working, lights, clutch, lighter, etc.] the parts list show's part # 8362 it's a 5-pin switch marked B-M-S-R and L according to the wiring diagram. I can't find a 5-pin switch with those exact letters or part number. Are all 5-pin switch's the same even if the letters are different? Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,521 #2 Posted 2 hours ago No 5-pin switches are all different. Up until now the 8362 switch was still available from Toro but looks like that has ended. It was a very expensive and heavy duty switch that carried the full current required for the starter motor. What many have done in the past is replace it with a lighter duty and less expensive switch plus add a starter solenoid to carry the starter load. The heavy wires going to the switch can be replaced with 14 gauge wires and a plug in connector can be added for the new switch. Your 8362 switch has 4-key positions. A less expensive and more common 103991 switch is a 3-key position switch which should work because you have a separate light switch. A 1960's - 70's Ford solenoid is a good choice 1 1 Share this post Link to post Share on other sites
lorenzo 0 #3 Posted 1 hour ago Thank you for the information Share this post Link to post Share on other sites
953 nut 70,064 #4 Posted 46 minutes ago 8 hours ago, lorenzo said: r. Are all 5-pin switch's the same even if the letters are different? Using the wrong switch would destroy your ignition system. As Gary told you the best way to go is replace the old switch with a 103991 and a solenoid. This diagram shows the wiring system using that switch and solenoid. Your electric PTO clutch will also be fed from the "A" terminal but should have a separate fuse. Share this post Link to post Share on other sites
ri702bill 13,271 #5 Posted 36 minutes ago 1 minute ago, 953 nut said: from the "A" terminal but should have a separate fuse. Absolutely add the fuse. When an electromagnetic cluth fails, it's one of 2 scenarios... the circuit goes "open" and nothing happens - or - the coil shorts to ground and THAT is why you need the fuse. There is quite an inrush of current - a spike - when the clutch is engaged and the rating of the fuse must be able to tolerate that... It is always better to get the high amperage load out of the keyswitch by using a solenoid - a device that was designed to do just that. The keyswitch lives longer that way. Do NOT just change to the 103991 keyswitch without adding the solenoid..... Share this post Link to post Share on other sites
evanloock 269 #6 Posted 24 minutes ago Wonder if the switch is still available from Indak? The E464A seems to be it. I am going to see if I can get any info from Indak.4 Position Key Switches (Stamped Keys) - INDAK Switches.pdf Share this post Link to post Share on other sites
lorenzo 0 #7 Posted 22 minutes ago Got it, thanks guys Share this post Link to post Share on other sites
