Cee245
Surprise! A 416-8 and a plan
953 nut
My favorite four letter word,                          FREE
  • Haha 2
ebinmaine
Nice gift!
702854boy
It looks like the mower belt might be in the wrong groove on the clutch bell.
Cee245
Good catch!  It sure is.  It's getting tossed along with most of the deck. It is pretty beat.  Several large rust holes.  Hopefully i can salvage a few things like spindles.
Edited by Cee245
Bill D
I like to run decks like that until they are completely unusable.   Save the wear and tear on the good ones.
  • Haha 1
rjg854
As long as decks work as they should and still give a nice cut, a good, experienced welder can take care of any holes.
Cee245
Thanks...  for me, thats the issue.  No welder amd limited experience.  You're right though,  it just is ugly.  No reason I can't grease and oil it to keep it solid for longer and just cut grass!
I Found out that I am 2nd owner.  I've gone over it a bit and to my surprise, it's actually in pretty decent shape overall. Even seat switch works! All original tires hold air and have the wear id expect for hrs shown. The meter says 527 or so and it appears to be accurate. Just left outside under a lean to.
From what I've seen the 6" tires seem to get bald by 800 hrs. The 8" generally have ok tread at 1000 hrs/use.
I set valve clearances.  Popped off flywheel and cleaned. Need to decarbon heads and find a new ignition switch.   I dont know how this actually works with all the corrosion.
The engine shroud had the obligatory mouse nest for a low cost machine lol.
Ordered full gasket set and will need a few other things as I have time to work on it.
Edited by Cee245
Spaced pictures apart
  • Excellent 2
ebinmaine
Great to see it getting the maintenance deserved!
Cee245
Gasket set came.  Need a fuel filter, but was able to get it running and purring. All of the electrical and the safety switches work.  Very surprised how well the harness is since it looks like it sat outside for a long time.
