Ed Kennell
60" deck belt routing
Ed Kennell
Found this belt routing decal on a 60" deck.    Did any 60" decks have the PTO belt on the bottom pulley?
May be an image of tractor, drill press and text
cleat
My 60" deck has the PTO belt on the bottom.
172261332_Deckcompletelyrebuiltsittingonground.JPG.e982dc9526d507a19dc798aafda9f12f.JPG
Ed Kennell
Thanks Cleat...the 82yo dog is still learning.
What was the reason for this belt change on the 60" decks?   belt axle clearance, radial load on the center spindle???
Edited by Ed Kennell
gwest_ca
I will guess that it was to get the longer blades down to a maximum blade tip speed of 19,200 feet per minute.
Handy Don
I think the question is: Why is the PTO belt on the bottom? The pulley could be inverted to be big on top and small on the bottom to get the same speeds.
gwest_ca
Wonder how the spindle pulleys ended up at the correct height?
Could they just be turned over?
Handy Don
Ah, that could be it. Aligning the deck belt to match the height of the other spindles without raising the overall height above the deck.
Ed Kennell
Good discussion..:thanks:  Don and Garry.
