SylvanLakeWH
B-80 Carb Help
SylvanLakeWH
I have a B-80 with a Walbro carb. Picked it up non-running and got her going... carb is now leaking, primarily from the bowl...
Trying to find a rebuild kit. Checked with K&B - no go. Anyone have a source / link?
I am told there were three different brands for carbs with some years ago to year switchovers...
Appreciate any suggestions.
SylvanLakeWH
Here's link to the thread on the purchase / clean up...
ebinmaine
Jim. Any chance you can get me the diameter of the bowl?
ri702bill
Why not switch it with a Carter Model N??
SylvanLakeWH
I'll check in the morning...
I'm not sure. Educate me. Are they the same for a 75-76 8 hp Kohler?
ri702bill
It should bolt right up, governor linkage & all.
ebinmaine
I'd be interested to know what years was what...
ri702bill
Be sure to get one from a comparably sized engine - there is a 2 digit bore ID cast in behind the choke plate up top - the higher the number, the larger the bore & airflow.
SylvanLakeWH
2 5/8 od
2 1/2 id
ebinmaine
1 hour ago, SylvanLakeWH said:
2 5/8 od
2 1/2 id
I'll check my stock here. I've had gaskets separate. Not sure what size.
SylvanLakeWH
Update
Fiddled with the rubber gasket a bit when I had it off to measure, readjusted and tightened it up and also tightened the fuel pump screws a bit. Seems to be holding after a cruise around the hood... still plan to rebuild but for now it's tight...
