SylvanLakeWH 32,738 #1 Posted 18 hours ago I have a B-80 with a Walbro carb. Picked it up non-running and got her going... carb is now leaking, primarily from the bowl... Trying to find a rebuild kit. Checked with K&B - no go. Anyone have a source / link? I am told there were three different brands for carbs with some years ago to year switchovers... Appreciate any suggestions. Share this post Link to post Share on other sites
SylvanLakeWH 32,738 #2 Posted 18 hours ago Here's link to the thread on the purchase / clean up... Share this post Link to post Share on other sites
ebinmaine 81,011 #3 Posted 17 hours ago Jim. Any chance you can get me the diameter of the bowl? Share this post Link to post Share on other sites
ri702bill 13,247 #4 Posted 17 hours ago Why not switch it with a Carter Model N?? 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,738 #5 Posted 16 hours ago 1 hour ago, ebinmaine said: Jim. Any chance you can get me the diameter of the bowl? I'll check in the morning... 54 minutes ago, ri702bill said: Why not switch it with a Carter Model N?? I'm not sure. Educate me. Are they the same for a 75-76 8 hp Kohler? 1 Share this post Link to post Share on other sites
ri702bill 13,247 #6 Posted 16 hours ago Just now, SylvanLakeWH said: I'll check in the morning... I'm not sure. Educate me. Are they the same for a 75-76 8 hp Kohler? It should bolt right up, governor linkage & all. 2 1 Share this post Link to post Share on other sites
ebinmaine 81,011 #7 Posted 15 hours ago I'd be interested to know what years was what... Share this post Link to post Share on other sites
ri702bill 13,247 #8 Posted 38 minutes ago 15 hours ago, ri702bill said: It should bolt right up, governor linkage & all. Be sure to get one from a comparably sized engine - there is a 2 digit bore ID cast in behind the choke plate up top - the higher the number, the larger the bore & airflow. Share this post Link to post Share on other sites
SylvanLakeWH 32,738 #9 Posted 20 minutes ago 16 hours ago, ebinmaine said: Jim. Any chance you can get me the diameter of the bowl? 2 5/8 od 2 1/2 id Share this post Link to post Share on other sites
