8ntruck 9,356 #1 Posted yesterday at 02:18 AM Was towing the lawn sweeper around the yard today with my 14-8 when it reved like crazy and took off. Upon opening the hood and looking at the throttle linkage, I found that the linkage between the throttle shaft on the carb had come disconnected at the governor arm. A bit of electric fence wire held things together to get the tractor back to the shed. What kind of fastener is used on the 90 degree bend to keep it in the governor arm? Mine appears to be threaded, but images of replacement linkages show that the short end of the 90 degree end is grooved for a C clip. No big hurry here, as I won't get a chance to work on the tractor until next week. I'm thinking a nut and Loktite or drilling a hole for a cotter pin are the easiest fixes. Share this post Link to post Share on other sites
702854boy 1,165 #2 Posted yesterday at 03:25 AM On our k301 and the one parts k321 we have it a small E-clip on the ends of the arm thingy. If i recall correctly its either 1/8 or 3/16 inch, I'm leaning more towards the 3/16 though 2 Share this post Link to post Share on other sites
Racinbob 13,224 #3 Posted 5 hours ago I have seen four different types. The little external retaining ring, a ball joint fastened to the carb lever, a 90° bend held in place with a special clip and the simple Z bend. Can you post a picture of what you have? 1 Share this post Link to post Share on other sites
peter lena 10,096 #4 Posted 1 hour ago @8ntruck local hardware , pull out drawer section , loaded with, all the goodies , don,t forget to lubricate , all / any related MOVEMENT AREAS , have PULL TO CLOSE extension springs , on all my choke and throttle set ups ?? , that way you always have an assist to slide function , tried that many years ago , dare to experiment with , REPEDITIVE ISSUES , kind of like , bearing failures , what could you possibly do ? pete Share this post Link to post Share on other sites
