Brockport Bill 2,480 #1 Posted 10 hours ago here's a new angle on removing mower deck pulleys from spindles that have been "rust welded frozen" on the spindle shaft. i have participated in numerous threads on this topic and am back in situation again -- using penetrant, map gas etc -- the two crow bars - hub puller etc. no luck !!!!!! It was suggested to me I need to get pulley collar hotter - and was suggested to use " Heat Induction Bolt Remover" -- or also maybe called "Induction heater" --- Has anyone used this tool to heat and remove the deck pulleys? I watched one video and the guy said when removing a nut the heat process will destroy the nut. Does that suggest the collar on top of pulley on the spindle shaft would be deformed ? I don't want to have to get new pulleys but if that's necessary then I guess that's the cost of removing the pulley ? any insights from anyone using this Heat Induction tool method? thanks 1 Share this post Link to post Share on other sites
8ntruck 9,336 #2 Posted 8 hours ago I've never used one, but I have seen induction heaters used in production production processes. The induction heaters are capable of heating things to a bright orange - hot enough to mess up any heat treatment the heated piece has. Chances are a heat induction bolt remover won't get quite that hot. It probably has an adjustment for the heat level. 1 Share this post Link to post Share on other sites
sqrlgtr 4,094 #3 Posted 2 hours ago (edited) I have this one and it does indeed work well. I have not used on mower deck pulleys but see no reason why it wouldn't work. It has helped with a few "frozen bolts" though. I like it a lot better than haveing to use an open flame for heat. Edited 2 hours ago by sqrlgtr 1 1 Share this post Link to post Share on other sites
953 nut 69,802 #4 Posted 1 hour ago Cut four wooden wedges from hardwood, place two of them under one side of the pulley where the tip of one is over the tip of the other, do the same on the other side of the pulley. tap on each wedge going from side to side so the upward pressure will be even. Continue driving the wedges in until they are as far as they will go. put the nut on your spindle shaft to protect the threads and give it s good hard hit with a BFH tool. The pressure from below and the shock to the shaft should do the job. 1 1 Share this post Link to post Share on other sites
