Chav88
15” 6 lug wheels (wheel weight size)
Chav88
I should have posted this BEFORE buying wheel weights but it was a good deal and they fit my tractor so no big deal.
 Anywho, I plan on getting 15” wheels for my d160 but I’m curious what the dimensions are for weights?
8ntruck
Years ago, I was on the Tire & Rim Association Wheel Weight Subcommittee.  We were working on standards to insure that clip on balance weights and the flange contours on steel and aluminum rims would play well together.
With that background, I was kind of wondering why you wanted to balance the wheels on your tractor.
Then the light came on you were wanting traction weights, not balance weights.
  • Haha 1
Handy Don
We each see the present through the lens of our past, right?
Edited by Handy Don
953 nut
Some "D" models were equipped with optional 15" rims and all "C-195" came with six lug 15" rims. WW-105 fits outside the 15" rim and is probably what you would want,          IF you can find them.
BradKahler
My 1973 18 Automatic (basically a D180) came with 15" wheels and wheel weights.  Attached are pictures of the weights and wheels.  For reference, the weights are 12-1/8" in diameter and are about 2-3/4" thick.
Chav88
All helpful information thank you I’m not really interested in them being the correct factory ones although I wouldn’t mind it. My main thing is I need traction with the big ol honking snow blower in the front.
 I found some cub cadet weights that actually fit the 12” rims. Haven’t decided if I’m going to go get them or drill out the ones I have already to match the bolt pattern.
