Retired Wrencher 7,003 #1 Posted 21 hours ago I took my time when I picked this up in the middle of the summer. It’s going to be my winter project so I decided to tear it down to the frame and clean it. Also go through one part at a time on assembly.. It’s never gonna be a pretty tractor.Or a show peace but it will be something you can use at the shows or just riding around the house. I’ve always wanted this model but I never could pull the trigger on one.I hope you enjoy the pics. 10 Share this post Link to post Share on other sites
953 nut 69,744 #2 Posted 19 hours ago Thanks for inviting us along for the ride. Share this post Link to post Share on other sites
peter lena 10,082 #3 Posted 18 hours ago @Retired Wrencher like the , opportunities of a bare frame ? lets you enhance things as you go ? the inner upper frame corner , easily holds a steel brake line 1/4 or 5/16 , ELIMANATING THAT FUEL HOSE BREAK DOWN ? ALSO THE PTO LEVER SET UP ? loaded with easy , improvements . like a roller stool ride around , so its a comfortable , look / see trial , done a lot of that , when you paint an improvement RED / BLACK , it disappears . only a suggestion . patana oiled finish , would be easy , and era correct . mule drive set up , gold mine for functional detailing , tried marvel mystery oil , on a paint soak , for days , perfect patina , enjoy it . pete Share this post Link to post Share on other sites
ri702bill 13,170 #4 Posted 17 hours ago (edited) Well - so far, so good. One item - the lower portion of the "F" plate with the booger-snot welds holding the patch in place. All that must be ground smooth to get the proper fit and support of the Unidrive. Thet area always traps water & rusts. Fix the welds, grind or wire wheel the whole face of the plate, prime & paint. It will last another 50 years... Edited 14 hours ago by ri702bill 1 Share this post Link to post Share on other sites
James Wright 3 #5 Posted 13 hours ago The point about the F plate trapping water is worth heeding, since that corrosion tends to come back if the welds aren't dressed properly. Grinding the face flat before priming makes sense for the Unidrive support to sit right. On the patina side, an oiled finish does suit the era better than fresh paint, though I'd be cautious about how much soak any bare steel gets before assembly. The roller stool idea is practical too, letting you test fit and check clearances without straining. Nice to see this moving forward. Share this post Link to post Share on other sites
peter lena 10,082 #6 Posted 8 hours ago @James Wright been doing lubrication paint maintenance for years , don't even think about it , just do it , every time I see dull faded finish , and its so easy , do it in stages , and go slow , letting the paint get warm in sun . or dry inside , dare to try a spot , pete Share this post Link to post Share on other sites
