stevebo
Is this a wheelhorse made attachment ?
stevebo
I just bought this sickle mower and was told it goes on a late 60's Radier. It is a set up I have never seen before. You basically use the same frame as a snow plow less the blade. You take the pivot pins out and remove the blade and then this slide into it's place. Any help feedback on this would be great. Thanks-
defed
i don't know for sure, but i would say that it is not a WH sickle. i have one just like it, it came off of a merry-tiller. it was a rototiller where you could remove the tines and replace them w/ wheels, then you could mount a sickle of mower deck on the front.
i don't recall seeing that type of guard on any of the WH front mount sickles.
i did make my sickle work on a 653 tho, and it worked fairly well, but was a bit heavy for that small tractor.
truckin88
Steve, what happened to thinning out the inventory and moving....haha just like I said I wouldn't buy another tractor this year....
That is sweet, does it work?
