ebinmaine 80,999 #51 Posted 9 hours ago 9 hours ago, sqrlgtr said: Yeah I was thinking they look like 12" front weights off small Farmall's but was wanting to make sure. Would like to add a set on the inside rears on my C-160. 8 hours ago, Sparky said: International Cub Cadet, they weigh in at about 25#’s each The ones I have here are the same but apparently have a piece of casting flash on the inside because they won't go over a Wheelhorse hub. Share this post Link to post Share on other sites
Sparky-(Admin) 26,559 #52 Posted 9 hours ago 22 minutes ago, Retired Wrencher said: This is not the first tractor, I’ve seen that you have internal weights. Do you have multiple sets of these? Good eye Gary! I have 4 pairs of these type of weights, and yes, I have em mounted up on more than one machine Share this post Link to post Share on other sites
Sparky-(Admin) 26,559 #53 Posted 9 hours ago 19 minutes ago, ebinmaine said: The ones I have here are the same but apparently have a piece of casting flash on the inside because they won't go over a Wheelhorse hub. Are they Sears weights? They offered a very similar weight but the hole was to small for a WH hub. I’ve had a couple pairs here but sold em off to a Sears guy Share this post Link to post Share on other sites
Sparky-(Admin) 26,559 #54 Posted 5 hours ago 3 hours ago, Sparky said: Are they Sears weights? They offered a very similar weight but the hole was to small for a WH hub. I’ve had a couple pairs here but sold em off to a Sears guy Like these Sears weights Eric, pretty much same weight but with a smaller center hole. Share this post Link to post Share on other sites
