Bar Nuthin 3,336 #1 Posted 12 hours ago (edited) The 754 has had the fuel tank apart and whoever did it used some kind of gummy sealant on both sides of the gasket. I noticed that it randomly shed drips of gasoline. By randomly, Maybe a drop or two one day - then dry for 3 or 4 days, then a drip - not necessarily in the same location. So, I took it off today and opened it up. The first thing I noticed is that none of the Allen head screws holding together were very tight. The second thing I noticed is that one of the threaded holes appears to have been repaired with JB Weld (or something similar). Perhaps that was their reasoning for not over-tightening the screws. The gasket is still perfectly flat with no indentation from being compressed, and the use of whatever kind of gasket varnish it was coated in. Anyway, the repaired crack appears to be contained to the inner side of the tank and everything else seems okay to my unexperienced eyes. I'm ordering a new gasket but looking for tips or advice from anyone who has had these tanks apart, or experienced anything similar. EDIT: I see Lowell references "Permatex Aviation Sealant" - possibly the goop I found on my tank? Anyone using something better? Edited 12 hours ago by Bar Nuthin 1 Share this post Link to post Share on other sites
Racinbob 13,206 #2 Posted 6 hours ago I've had several of those 2 piece tanks and never one that didn't leak to some extent. I don't think there's a gasket coating that exists that will permanently stop the issue. Really it's just a bad design. Wheel Horse came out with a service bulletin on it which involved actually installing an inner tank to solve the issue. I think I found a better method. There's many fuel tank liners out there and they will likely work as well but I've never tried them so I can't vouch for them but I know this stuff works. I think I can say permanent because I've never had one leak after using it. The key to it is cleanliness. I removed the old gasket and cleaned everything until it was sterile. I reassembled it and did some more cleaning. I let it sit in the sun several days to make sure any trace of moisture was gone. I plugged the threaded hole with a nylon fitting. I used maybe a quarter cup of Red Kote and swirled it around the edge where the two pieces meet. It doesn't take much. You don't need to coat the entire tank, just where the seal is. I let it dry several days and repeated. When I was done with the sealer I let it dry for many days. The latest one I've done is my current 854 and that's been 8 years now. 1 2 Share this post Link to post Share on other sites
sqrlgtr 4,042 #3 Posted 5 hours ago but the sealer I use is called "KREEM" and I just go ahead and do entire tank. 1 Share this post Link to post Share on other sites
WHX?? 58,276 #4 Posted 3 hours ago I used this KBS product on a 502 two piecer that @Andy N. now has. I was too sceered to take it apart for fear of bad threads. 'Sides figured by the time I got a gasket from Lowell and Permatex and possibly dealing with bad threads i was ahead. I was sold on this brand since I used it before on a Tecky oval tank that was full of pin holes with great luck. . I soldered up the biggest holes and the ones I missed had the seal gooing out which I considered a good sign. The big thing with this product is use all three components and follow the destructions to the letter. https://www.amazon.com/KBS-Coatings-52000-Sealer-Gallon/dp/B000IBDIX2/ref=sr_1_1?crid=176XR3BJQCOI&dib=eyJ2IjoiMSJ9.VRrcUbU1iANAvxPODhOQO3xt4DcrZWHcPSX9eZkdvpHNP0AC30S3mP6VPjtv37JPU2A2RJNaGbc8AmnTHRce8DIMeiJSqdUGig2reSj9k6XZhdY1NzqYLYl4jql6C5yxmVYB0ZFbrT28pgq5FqILHabaGezHzaV1IZ2vFvNV3whPFCC_HFrMsqdB4A_bMmbNBSp9eb_Ari5mNfQ_9LednHWKBRRpZeGOY_7yRFFb17yWDM2Gi2bqk0CWJ30gDQHETMdV444TCG6aL54YwpIM6xTZ2Ic3zOJz_dFeuT-MWjM.xIbyvN4P2rS1Xo9cNfEOAlhKVgq439WeW2G6P6b43vI&dib_tag=se&keywords=kbs+tank+sealer+kit&qid=1792930810&sprefix=kbs+tank%2Caps%2C205&sr=8-1&ufe=app_do%3Aamzn1.fos.9fe8cbfa-bf43-43d1-a707-3f4e65a4b666 2 Share this post Link to post Share on other sites
ri702bill 13,143 #5 Posted 2 hours ago 4 hours ago, Racinbob said: Wheel Horse came out with a service bulletin on it which involved actually installing an inner tank to solve the issue. I think I found a better method. The issues with that "approved" method - it ruined an otherwise good tank. The inner tank was most likely meant for a walk behind lawnmower - it held a QUART of gas! IMHO - not really a fix. Perhaps they should have just ponied up and brought back the 701 / 702 one piece tank?? 1 Share this post Link to post Share on other sites
Handy Don 17,525 #6 Posted 29 minutes ago 2 hours ago, ri702bill said: Perhaps they should have just ponied up and brought back the 701 / 702 one piece tank?? As you are very aware, aluminum castings like the 701/702 tank are very challenging to manufacture. I’m betting the two-piece, even with the extra parts and labor to assemble, was substantially less expensive and, I’d suspect that the vendor that made the one-piece tanks had shut down their line. No big surprise that so many fuel tanks today are blow-molded plastic. 1 Share this post Link to post Share on other sites
Bar Nuthin 3,336 #7 Posted 19 minutes ago (edited) Currently, I think my plan is to .. Glass bead (fine) the tank inside and out to clean up any corrosion Install the gasket ($10 eBay) dry with no goop Red Seal the inside of the tank Apply a satin (or matte) 2K clearcoat to the outside of the tank. Thoughts? Edited 18 minutes ago by Bar Nuthin Share this post Link to post Share on other sites
