lorenzo
battery not charging electro 12
lorenzo
just got an electro 12 that has been sitting for a while, jumped the battery to get it started but the battery is not charging. only showing 12 volts at the battery and the voltage goes down the longer that its running. should I be seeing a higher voltage coming back to the battery? Thanks
CasaytheMann
With the engine running you should see 13-14 volts. But I am not a mechanic.
lorenzo
correct, but I'm showing only 12v at 1/2 throttle. My owners manual wiring diagram shows only a rectifier, no regulator. I don't know how to test a rectifier. It shows an orange wire coming from the key switch, but doesn't show the color of the other 2 coming out of the rectifier. The tractor runs fine until the battery voltage drops down, the motor quits and needs jumped to start again.Thanks
953 nut
:WRS:
A dead battery will not charge from the engine. Charge the battery and have it load tested at an auto parts store, they will di it for free.
ebinmaine
Very important thing to remember in these.
The electrical systems are DC.
Direct. Current.
Bad ground is a bad circuit.
Clean the mounting points of ALL components of the charging system.
The Voltage Regulator must have good clean ground.
