T-Mo
1939 Ford 9N Aluminum Sheet Metal
ri702bill
Nice! Looks to be a Flathead 4 cylinder...
Polished aluminum similar to what some folks do to 701, 702 one piece gas tanks.... Some folks, not me.
davem1111
That is sweet - my brother still has Dad's 9N, need to get him to check for aluminum but I'm pretty sure it's not aluminum.
I owned an 8N for quite a few years, not a whole lot of difference between the 2 models at first glance.  Wish I still had that tractor.  I see these all over the place, begging for rescue, but I don't have the time or the money. :(
T-Mo
The 8N had a lot of improvements and can be easily identified from the 9Ns and 2Ns.  It's the 9Ns and 2Ns that people have a hard time identifying correctly.  The 2N is often misidentified as a 9N, due to the serial numbers on both start with "9N".  The 8N had a 4 speed transmission, while the 9N and 2N did not, it had factory running boards, the 9N and 2N did not, the brakes on the 8N were on the same side, the right, while the 9N and 2N had a brake pedal on both sides.  The rear wheels of the 8N were dished, while the 9Ns and 2Ns weren't.  The 8N had an air vent panel on the right side on the rear of the hood for the air breather, the 9N and 2N did not.  There were other changes, even in the 9N production run and the 2N.
Change_history_'39-'64_Ford_Tractors.pdf
