Prater 77 #1 Posted October 14, 2009 Sorry Guys, I have been very busy this year. No time to work on my projects but my dad picked up this tiller for $75 then blasted and painted it. Just curious if there is a schematic on it since it does not have the regular lift like my tiller does. Any help about this would be greatly appreciated. Also dad welded this for the front of his GT1100. Works great... Share this post Link to post Share on other sites
Docwheelhorse 2,875 #2 Posted October 14, 2009 OOOh OOOH OOOH!!!! I the Darth Vader all Black Look---how about a full pic of that GT1100. As a matter of fact I also had a GT1100 that I painted completly gloss black including the rims!! Tony Share this post Link to post Share on other sites
kpinnc 17,194 #3 Posted October 14, 2009 Stephen, the small piece of flat bar on the right side of the tiller (as if looking at your pic) between the casing and the lift assist spring has a 3/8 hole in the end of it. That's the "older" style lift for that series tiller. You can add the newer lift "plate" to the tiller cover like on a newer tiller. It would definitely be easier to raise with a manual lift that way. Just drill 4 holes and go! With your dad's fab abilities, you can prolly copy your tiller's if you can't find one. That's what I did with mine. Good luck! Kevin Share this post Link to post Share on other sites
Prater 77 #4 Posted October 14, 2009 Thanks kevin. Tony, if you look up my posts you can see the GT100 build from start to finish. Share this post Link to post Share on other sites
gwgdog66 23 #5 Posted October 15, 2009 OOOh OOOH OOOH!!!! I the Darth Vader all Black Look---how about a full pic of that GT1100. As a matter of fact I also had a GT1100 that I painted completly gloss black including the rims!! Tony Tony, It does look Sweet!! Here is the link http://www.wheelhorseforum.com/index.php?showtopic=9516 Share this post Link to post Share on other sites
Prater 77 #6 Posted October 17, 2009 Can someone measure the chain? We need to know how long it is supposed to be. Share this post Link to post Share on other sites
KyBlue 655 #7 Posted October 17, 2009 I just used a length... Adjusted it to have goo lift, and the right amount of depth... Just leave it long, and go by the trial - error method... Share this post Link to post Share on other sites
Docwheelhorse 2,875 #8 Posted October 17, 2009 Boy did that come out nice--I like the color!!!! Tony Share this post Link to post Share on other sites
Prater 77 #9 Posted October 25, 2009 I am back home now. We have the belt from TORO but the mid mount idler pulley that was made for me by a member here does not work. If you try to put tension on the belt the idler and pulley cause the belt to pinch on itself. Can someone take a few measurements for us so we can make the necessary mods? We need to know the diameter of the pulley and idler and the centerline length between the two. Thanks Steven Share this post Link to post Share on other sites
KyBlue 655 #10 Posted October 25, 2009 Stephen, Ill get mine out tomorrow and measure and photograph for ya. Share this post Link to post Share on other sites
Prater 77 #11 Posted October 25, 2009 Thanks Scott, we appreciate it. Share this post Link to post Share on other sites
KyBlue 655 #12 Posted October 26, 2009 Okay, Small Pulley is 2.5" the Large is 4.25" and edge to edge is 7.5" I got some photos of the two pullies, that Im uploading now, Ill post them shortly Share this post Link to post Share on other sites
Prater 77 #14 Posted October 26, 2009 Thanks Scott, can we get a picture of the backside and how the spring hooks up. Share this post Link to post Share on other sites
Prater 77 #16 Posted October 26, 2009 Thanks, we appreciate it. Share this post Link to post Share on other sites
Prater 77 #17 Posted October 26, 2009 Scott, we are going to build a new one from scratch. Do you mind getting a few more measurements? We need the length of the flat bars and the distance from the rod stop for the atach-o-matic to the backside of the flat stock bar. Thanks again. Share this post Link to post Share on other sites
KyBlue 655 #18 Posted October 26, 2009 Thats Fine. I'll try to get it tonite, but it might be a few days. I never know how work is gonna go, what time im gonna get home, or have to go back..hahaha Share this post Link to post Share on other sites
Prater 77 #19 Posted October 26, 2009 No problem, thanks I know about work. I am home until the 3rd then its off to San Diego... Share this post Link to post Share on other sites
