Charrie
Where to find a parts manual for 1985 416-8?
Charrie
If I am not mistaken, Toro bought Wheel Horse in 1986. When  I visit theToro site, I don't think the parts list goes back that far.
There is a 50 yo mower repair shop going out of business and they had an initial sell off last year. Now they are just trying to empty the building for the most part. 3 days left before they close permanently. I am trying to make a list of parts that I might need in the future and see what they have left.
So if I could find a good parts list with part numbers for my 1985 416-8  Model #3116K801  serial #11370 ?
Also I welcome all suggestions for parts that I should be looking for. I also have a 1994 520-H They seem to have a small Kohler parts section and no actual Wheel Horse section. He said that some local Wheel Horse fan already came in and bought most of what he had.
Also, he did not have a full carb kit for the k341 but gave me two different packages with carb parts that I believe do fit. Maybe someone here knows?
Kholer 25 757 11     740 kit
Kohler 25 757 03-s  Kit, Float Repair
Thanks
Prts I did find
Fuel cut off valve
Kholer fuel  pump
2 sets breaker points, No condenser.
1 spark plug
PTO to mower belt
Air filter and pre-filter.
gwest_ca
The illustrated parts list we have is shared with other models at the time so be careful selecting parts. If you look at the engine page you may be able to identify the included models.
This is what Toro has
  • Excellent 2
Ed Kennell
I look for those gold mines.  Buy it all by the bucket full.
  • Like 4
953 nut
The "Bucket Master" has sspoken!
  • Haha 4
  • Heart 1
Charrie
Thanks for the replies. I found the link with the 416 info in manual section I believe.
Since they don' t have any Wheel Horse parts then I think I'll focus on engine parts. For the 416, all of the info I find on the engine is the K341S 71371.
I haven't checked to see if they have any Onan parts but perhaps need to do some research there also.
They  used a company Rotary for their aftermarket parts so maybe a choke or throttle cable.
This is different from finding a replacement part for something broken. Without a detailed parts diagram with a part number page, I have to look up each part # and then cross it over to what he has left.
Anyway Thanks and YES buckets!
If anyone is in the Dalton GA area and interested I'll be contacting the guy and make sure its ok to make this public. I think thelast3 days will be Tuesday-Thursday.
Charrie
By looking at the number of posts you guys have made, one or all of you might know the answer to this question. So I was looking at the Kohler fuel pump i bought and it has what appears to be a priming arm built on to  it. My original pump does not. It appears like the pump will  fit though. Seems like I read here on the forum somewhere about some of the tractors being hard to start because the tank is under the seat. I know the fuel drains back out of the 520 after a couple of weeks.
Thanks
May have found a partial answer. Came across a post where a k series engine was running an old welder. The engine used the old wrap around rope pull start. That engine also used a fuelpump with a priming arm built on to the pump.
Edited by Charrie
add information
Charrie
Thank you for that link. I just spent the last hour copying Kholer part numbers to my list.
I hope it is ok to post this link I found
Kohler Engines Parts Manual
K341 -16HP
Specs 71105 - 71384
https://www.barrettsmallengine.net/partslist/kohlerk341-16hp.pdf
Also this manual from Kohler
https://resources.kohler.com/power/kohler/enginesUS/pdf/tp_2379.pdf
Edited by Charrie
add information
Charrie
I spoke with the man in charge and he said that it is ok to post directions for anyone who wants to come buy and look for parts. They are starting to box up the shelves this week  but said that the mower section would be last.
They have a good bit of stuff throughout the store and if one of the boxes on the floor catches your eyes, ask them how much.
As far as mower parts, Rotary is their aftermarket supplier. Today i found a starter, partial gasket set, one crankshaft seal, and one of the pepper shaker mufflers for my 416,
 They have a truck load of chain saw parts if someone knows what to look for. Also lots of different mower blades for unknown machines.
Dawnville Hardware.
1358 Dawnville Rd NE,
Dalton, GA 30721
Edited by Charrie
