peter lena 10,123 #1 Posted October 7 https://www.google.com/search?q=shoulder+bolts+tractor+supply+3%2F8+x+2+1%2F2&sca_esv=8de974bdd654ed99&rlz=1C1CHBF_enUS866US866&biw=1028&bih=606&sxsrf this is a regular for me , setting up ANY SWING MOVEMENT START , as stated , just do not bolt it on together , MAJOR MISTAKE ? its too tight or loose , add flat washers on each end to ensure , swing is on smooth bolt area , aerosol red grease , secure PERFECT MOVEMENT , with elastic LOK NUT , literally DIAL IT IN ! also do this from a roller stool ? comfortably sitting / looking at the m REPEDITIVE PROBLEM . do a trial on your own , issue , thats how I started , that pto / mule drive area , is LOADED WITH EASY ELIMINATIONS , years in , mine have never returned . look for best price , availability , then do a small TRIAL ? thats how I started , my changes are HIDING IN PLANE SITE , and they CONSISTANTLY WORK , isn't that what you want ? my plow swing quadrant , works like a rifle bolt , smooth , quiet , easy . try something . pete 2 1 Share this post Link to post Share on other sites
ri702bill 13,389 #2 Posted October 7 My only concern with shoulder bolts - the aggressive undercut between the inner end of the threads and the working diameter. Side force, even not excessive, can shear them in two. I often specified precision shoulder bolts, as the threads are held very close to being concentric with the working diameter. The receiving part would have a close-fit shallow counterbore or pocket, then the threads. This way, the shear forces went into the part - the threads did just the fastening... Share this post Link to post Share on other sites
peter lena 10,123 #3 Posted October 7 @ri702bill , have years on this , never had a failure , then went after related , pto lever start issue , at battery tray , the heim joint in place of sloppy trundle , initial washer filling play point ,shoulder bolt , as soon as you squeeze the swing lever on plow quadrant lever , the amazing ease is showing you its gain over a chronic issue , never had a failure , solid wire , instantly shows you its difference, blade swings with ease , tractor has bins of them . really never had any failures , also graphited my blade face ? snow slide off is ridiculous , lets you back plow , for easier clearing , pete 1 Share this post Link to post Share on other sites
ri702bill 13,389 #4 Posted October 7 36 minutes ago, peter lena said: @ri702bill , have years on this , never had a failure Your scenario does not put the threads in shear - much better than OE... 1 Share this post Link to post Share on other sites
peter lena 10,123 #5 Posted October 7 @ri702bill ironically most of the stuff I have changed over to , you don't even initially see, when I did the plow frame over , used a roller stool to scoot around and analyze problem function , that lets you hunt around for every stage of movement . thats where you find the problems , use the same theory to eliminate / chronic problems . w/h tractors are a gold mine for improvement , bought my c-85 new in 82 , love that thing , also have 2 other units . keep in touch , pete 1 Share this post Link to post Share on other sites
