KeithB 6 #1 Posted October 13, 2009 Got the frame cleaned up , primed and painted This tractor will be from at least 3 different tractors. The frame and tin work is a C-160 eight speed, the trans is 8 speed 8 pinion from a C-81, the motor is a 12 HP Kohler from a C-120 Auto. The C-160 tranny has to be taken apart and get new seals at some time, it will be a spare or go in another tractor. Next i gotta get the hood stand cleaned up and painted. Then i can start assembly. Maybe i should name it Frankenstein I have the C-120 auto frame all cleaned up it, will be going under a B-80 eight speed that someone screwed up the holes where the motor bolts down. It to will also be a GT puller. The C120 and B80 frames are the same part number. One will be a stock 12HP class and the other stock 18 or 20 HP class. The frame pic is not to good, but the paint came out pretty good for a rattle can: Trans and new hitch i bought off EBay, the bolts need trimming. Will be welding 4 tabs to top and bottom of hitch to bolt wheelie bars too The tires are 26x12-12 on 13" wide wheels. Share this post Link to post Share on other sites
KeithB 6 #2 Posted October 15, 2009 got the hood stand and pedals painted. While they dry started assembly: Share this post Link to post Share on other sites
KeithB 6 #3 Posted October 15, 2009 More assembly today. I think the foot rests and battery box will be black. Next will be painting the motor black, and installing it so i can work on the wiring, will be pretty basic wiring being a puller. For some reason, maybe lighting the the pics a re bit fuzzy Share this post Link to post Share on other sites
chazm 412 #4 Posted October 16, 2009 Coming along nicely Really digging those those big gummy aggies on the back Keep the pics coming Chaz :ychain: Share this post Link to post Share on other sites
KeithB 6 #5 Posted October 16, 2009 Thanks Chaz, will do, will be painting the motor black next and working on wiring. Share this post Link to post Share on other sites
KeithB 6 #6 Posted October 16, 2009 Here is the C160 i started with and the C120 auto i stoled the 12 HP Kohler from Share this post Link to post Share on other sites
KeithB 6 #7 Posted October 18, 2009 More progress; gave the motor a quick paint job, it may well come back out and get some work done. Battery box and air cleaner needs painted and need to dig up a 4" pulley, i broke mine getting it off the 16HP motor . working on the wiring now. doing all new, Walmart has 16 ga for $3 a package in various colors and gotta get some terminal ends, i think i have them all except the push on for the switch and ammeter. then will be time to build weight brackets, wheelie bars, and work on the rest of the tin work. Share this post Link to post Share on other sites
KeithB 6 #8 Posted October 20, 2009 Wiring is done, charging system works good, stuck a gas tank in, got it running and drove it around the yard a bit Took me a while to figure out the clutch won't completely release without the belt cover on. Found out i need to space the rear fender up off the big tires and the belt cover needs painting. Little by little. Took battery box out to paint. Share this post Link to post Share on other sites
KeithB 6 #9 Posted October 20, 2009 Also started on the B80 eight speed project, going on a C120 Hydro frame. The B80 frame was a bit rough and the motor mounting holes were messed up. Share this post Link to post Share on other sites
Stress Test Pullin 0 #10 Posted November 12, 2009 looks good:D and lovin the big super lugs out back Share this post Link to post Share on other sites
gardentracotpullinfool 0 #11 Posted May 13, 2010 nice looking tractors there!!!!! Share this post Link to post Share on other sites
KeithB 6 #12 Posted May 13, 2010 Thanks, have you seen my 12 and 18 horse stock pullers? see here: http://www.wheelhorseforum.com/index.php?showtopic=13307 http://www.wheelhorseforum.com/index.php?showtopic=16148 Share this post Link to post Share on other sites
