1973Auto
18 hp Courage sputtering
1973Auto
Hello all. I have a kohler 18hp courage that just started running like crap.  Just use the tractor for mowing my tree stand paths. The 2 second video has it sputtering when driving, but when I put the break on it runs fine. I sprayed carb cleaner in it and didnt do anything. Could be a bad spark plug? Thanks!
  • Confused 1
WHX??
Two second vid don't do much for me. Maybe starving for fuel???
gwest_ca
Service manual
Wild Bill 633
A common saying is, "It takes courage to run a Kohler Courage."
Edited by Wild Bill 633
1973Auto
2 second vid is all I could upload.  I only use this tractor for mowing paths, I know its a junk engine.  Its actually the second on This tractor.  The original was 20hp. Just trying to get it going so I can use it to drag deer out of my woods. It was running fine now, spits, sputter, backfire, while driving, at ideal its fine.
953 nut
Have you changed the spark plug? ?  ?
:confusion-shrug:    Could be some debris around the flywheel that gets caught in the air gap between the magneto and flywheel, pull the tins and take a look.
