slk
Seat on C120
slk
Is it just me or is the seat really close to the dash/steering wheel of the tractor. I feel so cramped in that small space. I have not looked all that close yet but I do not see where I could move it back about 6” or so.
ebinmaine
Got pics?
I'm a "not small" person. My seats are all set back 2 inches from the OE stock furthest rear point.
slk
I will get some pics tomorrow
Handy Don
I have added seat slides to the two tractors I maintain that have users with both compact and elongated statures. The slides have 6” of travel that I positioned to 3 in each direction from stock.
Do be careful not to position the operator’s weight too far to the rear--the stock position is pretty much directly over the rear axle.
ri702bill
Agreed - no need to do a backflip!
slk
This is what the previous owner rigged up
ebinmaine
Appears to be a congflagablabruation of two different systems. Maybe.
Does you tractor have the flip back seat pan/fender or the flip forward seat?
squonk
I had a similar set up on the B80 I had. You can elongate the slots where I circled to get the springs mounted farther back. They also make springs with slots built into them. I have seen them on E bay quite often.
M84077 John Deere Seat Spring Mounts Pair 108 111 111h 112L 116 116h
Handy Don
Gotta get ‘em pre-made, of course. Adding slots to spring steel is, well, a good way to dull tooling.
slk
Well guys I was able to drill out the spring steel but I could only go back about 2”. Got it all back together and it is a little better. Still feels very cramped. I am still over the rear axel though. If I can find a new seat that might help as well. I can’t really put my hand on mine to get in as the pan is cracked. So I am having to thread my leg through all the gear selectors to get in and not much fun doing that at my age.
Handy Don
One of the reasons I like my round hood is that I sit on the seat and then swing a leg over the steering wheel (having lowered the lift arm, of course).
At some point, if the mount/dismount becomes undoable, you might have to consider a zero-turn. :sad:
ebinmaine
Can you show current pics?
In all seriousness.... the more you move, the more you'll likely be able to.
But you shouldn’t need to "thread through".
This is how I  ( the not small Bear ) gets on all my tractors...
6 hours ago, Handy Don said:
consider
Or a Wheelhorse 200 series with a pass through design.
  • Excellent 2
Retired Wrencher
Nice vid Erick. There is always something you can learn. The only thing is when you get old limbs do not react as quickly as you did it. I have to mount the mount the B 100. I’m glad I put that nonslip stick on paper lack up a better word. It works well I buy it on a roll at HD. Enjoy your day, buddy.
WHX??
My safety classes I preach three points of body contact with the tractor when getting on or off. Especially true for high wheel or big tractors with ladders. Never grab or use any levers or shifters.
Edited by WHX??
speeling
  • Excellent 2
ebinmaine
Agreed.
Forklifts. Truck cabs. Truck bodies or beds. Cranes.
Always use the correct supplied handles.
I've had discussions and refused to sign off on instructions for forklift training at one point. Some ball of brightness in management wrote that the steering wheel is an improper grab point.
Incorrect in many situations.
Some machines and most semi trucks have the steering wheel as a primary point of the 3...
ohiofarmer
If your back is aching and you cannot dismount as Erick did, a lower seat back and an auto trans with a hydraulic lift will enable you to swing a leg over the steering wheel.   I have done it both ways. With a manual lift be careful as it is pretty easy to bruise your leg on the handle
ebinmaine
Oooooooooo. YES!
I've invented new "sentence enhancers" after doing just that.
