BPEisenhower
Couldn't pass it up
JERSEYHAWG /  Glenn
Cant wait to it again. Your scored big time.
ebinmaine
Good catch!
SylvanLakeWH
:eusa-clap:
ri702bill
Nice score... how's the Automatic?
You bought a mule drive & got a free tractor & deck!
  • Haha 1
oliver2-44
Great find!
Tires even look good.
Is the paint all original?
parsonsponyz
Nice score.  Looks like really nice tractor
Glad there's not a lot of deals like that around here or I would have to make the stables larger.
BPEisenhower
Early morning with the Hotsy. Big believer in Citri Blast and Cascade. I did get everything cleaned and I think it's a good candidate for a repaint. No dents or holes. Surface rust isn't bad but, I do like the wet look. LoL 🤣. Also, I did get the original rear tires with it and do hold air, no cracking. I can see myself adding more C series to the collection. Show more pictures later! Enjoy your morning Horse fans! 🌞 Apologies for the hazy photos but I had my washer set at 280°. Can't stand greasy build up!
  • Excellent 5
peter lena
@BPEisenhower  very often suggest , getting  paint recovery  started  ASAP , like penetrating oil  total spray down , let it sit  for weeks  , to penetrate and establish easier base , rub out , sun heat is best for absorption  , but a darker shade is showing you the way ,  this is regular  stuff for me , gently do it in stages , finish with a  6" electric  palm buffer , cleaner wax , TRY A SMALL  test  area . pete
BPEisenhower
I often wondered if a lubricant of some type would help. Considering that everything that was caked in grease was preserved underneath. However, someone did rattle can the right fender 🤬. Definitely going to change motor oil and figure out what type of ATF is best in rear end. Also, need to locate the engine screen. Magnum plastic don't look correct and, it has the original muffler turned out.... I'm picky but it must be correct since it's there! LMAO 🤣. Thank you for the advice, I'm grabbing a gallon of WD and spray bottles
8ntruck
If the muffler is original, it is not mounted properly.  The stock muffler mounts roughly vertically in front of the engine with the exhaust exiting the left side.
sqrlgtr
I agree and may have an extra screen ( will have to check) yours for $5 dollars plus shipping if you promise to fix muffler.:D
BPEisenhower
I would gladly pay for a correct screen 😜. The muffler is driving me nuts seeing it upside down. Definitely getting put in it's correct configuration 😁. Had to get other work done before I could do much more with it but, since the girlfriend is visiting new grand baby, I got plans for the evening! 🤣. Steam cleaning definitely has improved its image!  Can't believe how hot water and soap can change appearance
BPEisenhower
So, do I get extra credit for finishing early? LMAO 🤣. Had the service truck so I used the torch to heat nuts, pipe expander to save downpipe and muffler.....IMG_20261003_195028.jpg.b3e539065806bc0586a2abaa939003ec.jpg
Retired Wrencher
You definitely hit the jackpot pot with this one. I guess good deals can still be had. Enjoy it. Take good care of it.
JoeM
Wire brush and some heat paint and turns it into a going to town rig!
that muffler is worth 50 clams itself
BPEisenhower
Thank you so much! It's something that all the Horses I find have been abused and parked to be replaced with a big box store plastic fantastic. Sold quite a few to other collectors and want them back. LoL. I believe the C series is addictive 🤣
  • Haha 1
BPEisenhower
Already had two people ask if it was for sale...NO!  They were surprised to see points and a coil....not to mention a carburetor. Then want to compare it to a Craftsman 😮. The expression on their face when I pointed out the bolt on wheels as apposed to the lock ring and woodruff keys on theirs...
ebinmaine
Can confirm. I have quite a few.
adsm08
Good grief. I am actively not looking for another tractor, and I don't much care for the looks of the 70s units. If I ran across that for $50 I'd be trying to figure out if I could drive it home.
BPEisenhower
I did put the original rear tires back on and ran a rag of WD40 across it and now I want a set of ag tires. LoL. Going to look into adding hydraulic lift since it's doing so well! Might even go for sending off the motion lever and PTO lever in for chrome. 😁. Got a few pics and a cold start, no choke.
Edited by BPEisenhower
  • Excellent 3
sqrlgtr
I cannot find the screen I was thinking about but if I run across it in next day or two will let you know.:handgestures-fingerscrossed:. Great job on muffler relocation.
Edited by sqrlgtr
BPEisenhower
Not a problem! Thank you for the motivation 🤣. I've got a few things done and I can't be happier!
BPEisenhower
And to add more icing to an already delicious cake, I seen the deck from my C195 looking lonely since thrower is on so.... Why not? I like bigger deck, tractor looks beefy or better😁. Plus, I found a NOS mule drive to top off the whipped cream and sprinkles. The girlfriend asked what I did all weekend after I clocked out yesterday at 1 and pointed at the Horse. I got a cold stare of unimpressed. However, I did get a purple LED lit tree for Halloween set up in the living room and lights on the wall. I'm safe, for the next few days 😜. Have a great evening everyone!! I'll keep you all posted
  • Excellent 4
Retired Wrencher
Well Eric, you can justify the need for having all those tractors you live off the grid. I can’t believe I own five now. Don’t know why, but I own them three is my ideal to have one might go in the spring not sure.
