BPEisenhower
Couldn't pass it up
JERSEYHAWG /  Glenn
Cant wait to it again. Your scored big time.
ebinmaine
Good catch!
SylvanLakeWH
:eusa-clap:
ri702bill
Nice score... how's the Automatic?
You bought a mule drive & got a free tractor & deck!
oliver2-44
Great find!
Tires even look good.
Is the paint all original?
parsonsponyz
Nice score.  Looks like really nice tractor
Glad there's not a lot of deals like that around here or I would have to make the stables larger.
BPEisenhower
Early morning with the Hotsy. Big believer in Citri Blast and Cascade. I did get everything cleaned and I think it's a good candidate for a repaint. No dents or holes. Surface rust isn't bad but, I do like the wet look. LoL 🤣. Also, I did get the original rear tires with it and do hold air, no cracking. I can see myself adding more C series to the collection. Show more pictures later! Enjoy your morning Horse fans! 🌞 Apologies for the hazy photos but I had my washer set at 280°. Can't stand greasy build up!
peter lena
@BPEisenhower  very often suggest , getting  paint recovery  started  ASAP , like penetrating oil  total spray down , let it sit  for weeks  , to penetrate and establish easier base , rub out , sun heat is best for absorption  , but a darker shade is showing you the way ,  this is regular  stuff for me , gently do it in stages , finish with a  6" electric  palm buffer , cleaner wax , TRY A SMALL  test  area . pete
BPEisenhower
I often wondered if a lubricant of some type would help. Considering that everything that was caked in grease was preserved underneath. However, someone did rattle can the right fender 🤬. Definitely going to change motor oil and figure out what type of ATF is best in rear end. Also, need to locate the engine screen. Magnum plastic don't look correct and, it has the original muffler turned out.... I'm picky but it must be correct since it's there! LMAO 🤣. Thank you for the advice, I'm grabbing a gallon of WD and spray bottles
