ldm2pe 0 #1 Posted September 29 Hello, I recently purchased a used 48" mower deck with recycler baffles and rinse port, but it has no serial or model number present, and I cannot seem to determine what Toro unit it was meant for, it's similar to one for the 300-500 series but not exactly the same and it has insufficient rear lift brackets that require repair, probably due to the weight of this beast with the added baffles. Any help identifying would be appreciated. Thank you. Share this post Link to post Share on other sites
Bill D 3,167 #2 Posted September 30 It looks like a deck for an XT series tractor. You should be able to make it fit l, but it may require some welding and the deck carrier assembly from a 300/400/500 series deck. Share this post Link to post Share on other sites
Brockport Bill 2,479 #3 Posted September 30 3 hours ago, Bill D said: It looks like a deck for an XT series tractor. You should be able to make it fit l, but it may require some welding and the deck carrier assembly from a 300/400/500 series deck. yup -- looks like that one a couple yrs ago we saw that Tom had at Reardon Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,508 #4 Posted September 30 Here is a 48" deck for the XT series. The recycler baffle was optional. https://www.partstree.com/models/78290-toro-48-side-discharge-mower-deck-for-xt-series-tractors-sn-240000001-240999999-2004/ Share this post Link to post Share on other sites
