leabassett@sbcglobal.net 190 #1 Posted September 27 Like the title says what is it? It is marked Charger 10 on the side. But the motor looks original and is a 1976? Hydro drive manual lift. Starts right up too. Thanks 2 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,557 #2 Posted September 27 Get down low and look up under the dash panel for an ID plate 2 Share this post Link to post Share on other sites
leabassett@sbcglobal.net 190 #3 Posted September 27 10 minutes ago, gwest_ca said: Get down low and look up under the dash panel for an ID plate Thanks I will. Here is a pic of the front. 2 Share this post Link to post Share on other sites
leabassett@sbcglobal.net 190 #4 Posted September 27 The tag says 17931 Share this post Link to post Share on other sites
rmaynard 17,659 #5 Posted September 27 1-7931 1968 Lawn & Garden Tractor Charger 9 Automatic Tecumseh HH100-115095B 10 Sundstrand 90-2046 Looks like a few mods have been applied 4 Share this post Link to post Share on other sites
leabassett@sbcglobal.net 190 #6 Posted September 27 It has a 1976 Kohler 10HP in it 1 3 Share this post Link to post Share on other sites
oliver2-44 11,846 #7 Posted September 27 The Kohler is a big Plus 4 Share this post Link to post Share on other sites
leabassett@sbcglobal.net 190 #8 Posted September 27 Will my snow plow fit it from my 312-8 ? Share this post Link to post Share on other sites
rmaynard 17,659 #9 Posted September 27 (edited) The Kohler is a probably a transplant. The HH100 was not a good engine (in my opinion), especially since the electronic ignition module is no longer available. The 312-8 plow should be able to be fitted to that tractor as long as you have rear axle mounts and a lift handle. If I am wrong, someone will be sure to correct me. Edited September 27 by rmaynard Share this post Link to post Share on other sites
adsm08 5,247 #10 Posted September 27 (edited) 28 minutes ago, rmaynard said: The 312-8 plow should be able to be fitted to that tractor as long as you have rear axle mounts and a lift handle. If I am wrong, someone will be sure to correct me. It should work. A lot of the tractors from that body style fell into the "short frame" category, while a 312 is longer. The biggest issue there would be alignment of the lift point on the plow to the attachment point on the rocker shaft. But given the gear-drive starter and the battery in the original location this unit likely has the longer wheel base. Edited September 27 by adsm08 1 Share this post Link to post Share on other sites
pfrederi 21,342 #11 Posted September 28 What is the spec # of the engine?? Share this post Link to post Share on other sites
evanloock 271 #12 Posted September 28 (edited) 2 hours ago, adsm08 said: It should work. A lot of the tractors from that body style fell into the "short frame" category, while a 312 is longer. The biggest issue there would be alignment of the lift point on the plow to the attachment point on the rocker shaft. But given the gear-drive starter and the battery in the original location this unit likely has the longer wheel base. The Charger 9, as are all Charger models, is long frame. Edited September 28 by evanloock 3 Share this post Link to post Share on other sites
leabassett@sbcglobal.net 190 #13 Posted September 28 21 hours ago, pfrederi said: What is the spec # of the engine?? The tin says its a 1976 10 HP Share this post Link to post Share on other sites
leabassett@sbcglobal.net 190 #14 Posted October 2 I may put it up here for sale. Not sure I want to keep her outside all winter. But would make a good trailer puller. 1 Share this post Link to post Share on other sites
