leabassett@sbcglobal.net
What do I have
Like the title says what is it?  It is marked Charger 10 on the side. But the motor looks original and is a 1976? Hydro drive manual lift. Starts right up too. Thanks
gwest_ca
Get down low and look up under the dash panel for an ID plate
Thanks I will. Here is a pic of the front.
The tag says 17931
rmaynard
1-7931
1968
Lawn & Garden Tractor
Charger 9
Automatic
Tecumseh
HH100-115095B
10
Sundstrand
90-2046
Looks like a few mods have been applied
It has a 1976 Kohler 10HP in it
  • Excellent 2
oliver2-44
The Kohler is a big Plus :icecream:
Will my snow plow fit it from my 312-8 ?
rmaynard
The Kohler is a probably a transplant. The HH100 was not a good engine (in my opinion), especially since the electronic ignition module is no longer available.  The 312-8 plow should be able to be fitted to that tractor as long as you have rear axle mounts and a lift handle.
If I am wrong, someone will be sure to correct me.
Edited by rmaynard
adsm08
It should work. A lot of the tractors from that body style fell into the "short frame" category, while a 312 is longer. The biggest issue there would be alignment of the lift point on the plow to the attachment point on the rocker shaft.
But given the gear-drive starter and the battery in the original location this unit likely has the longer wheel base.
Edited by adsm08
