FLtractor
856 starter gen Main Bolt.. advice
FLtractor
Evening,
attempted to remove 856 starter generator to bench test it but didn’t know there was a very difficult to reach bolt in the middle underneath it, securing it to tractor engine. Any advice how to best reach and loosen it? Couldn’t get a very good picture being outside in dark but it’s directly middle holding it on.
IMG_4008.jpegI believe it is # 14 bracket bolts from Pfrederi”s diagram from a different post.
Edited by FLtractor
adsm08
That bolt isn't that hard to access. You already have the hood open and the belt guard off, at that point it is practically out in the open.
Sight unseen I would suspect the real problem is your tooling.
FLtractor
Maybe it’s different bolt I’m thinking of.. this one had bracket blocking easy access to it.  But only looked at it quickly in the dark with phone flashlight. Will have to look better in daytime
pfrederi
All you need to remove is #14.  Goes through the Gen body then the mount then the gen body on the other side  The mount itself #13 stays on the engine
  • Excellent 2
FLtractor
I figured that out the hard way today before I read your note haha.. but thank you for the advice and helpful info.
