FLtractor 202 #1 Posted 12 hours ago (edited) Afternoon, when using a multimeter- what would be the proper way to check the ignition switch terminals and starter to see if that’s where my no start noise problem lies? I have one of those 7 function multimeter from harbor freight- lost manual so been looking online but still confused.would not allow me to attach picture of mutimeter I have, as Wheelhorse website states I have used all my attachment space. Edited 12 hours ago by FLtractor Share this post Link to post Share on other sites
702854boy 1,117 #2 Posted 11 hours ago If the multimeter has an ohm setting on it, signified by an upside down horseshoe, you can hook one prong up to the b(battery) terminal and see if the continuity to the other terminals. If there is continuity it should read 0. Even better if the meter has the beep function because then it will beep if there is continuity. Share this post Link to post Share on other sites
squonk 47,956 #3 Posted 11 hours ago No. 1 Become a supporter and have unlimited picture posting capability. No.2 DO NOT have the battery connected using a meter on OHMS. You can destroy the meter. What do you mean by " No Start Noise?" Share this post Link to post Share on other sites
FLtractor 202 #4 Posted 11 hours ago 12 minutes ago, 702854boy said: If the multimeter has an ohm setting on it, signified by an upside down horseshoe, you can hook one prong up to the b(battery) terminal and see if the continuity to the other terminals. If there is continuity it should read 0. Even better if the meter has the beep function because then it will beep if there is continuity. Thank you for the info. Not sure it has continuous beep. Share this post Link to post Share on other sites
FLtractor 202 #5 Posted 11 hours ago 6 minutes ago, squonk said: No. 1 Become a supporter and have unlimited picture posting capability. No.2 DO NOT have the battery connected using a meter on OHMS. You can destroy the meter. What do you mean by " No Start Noise?" #1. I wonder if my membership has expired .. been a year already I wonder.. gonna have to check. #2. So even with a cable going from starter to ignition switch “S” terminal.. without battery connected- the meter will Still read when electrical output level? #3. ever since I moved the ignition switch to a different much better fitting dash hole- of 856- that’s when the starter made softer nosies when key turned then eventually sounded like a soft electrical air puff fart noise then nothing. Share this post Link to post Share on other sites
squonk 47,956 #6 Posted 11 hours ago 1 minute ago, FLtractor said: #1. I wonder if my membership has expired .. been a year already I wonder.. gonna have to check. #2. So even with a cable going from starter to ignition switch “S” terminal.. without battery connected- the meter will Still read when electrical output level? #3. ever since I moved the ignition switch to a different much better fitting dash hole- of 856- that’s when the starter made softer nosies when key turned then eventually sounded like a soft electrical air puff fart noise then nothing. Redo your membership and post pics of your wiring. Ohm setting measure continuity through a wire not voltage. Are all the generator mounting points clean with no rust, dirt and paint? Share this post Link to post Share on other sites
Achto 32,425 #7 Posted 10 hours ago 1 hour ago, FLtractor said: wonder if my membership has expired .. been a year already I wonder.. gonna have to check. Click on Store(support RS) on the line a the top of the page. Should be some thing pending for you to renew. Share this post Link to post Share on other sites
