CRF857
Land Pride
CRF857
Local mower shop hauled this one in.
Owner claimed he just changed the oil, started mowing and it died, wouldn’t turn over.
Shop owner put it on the lift, then exclaimed. OH $&17!!!
picture shows the problem.
  • Haha 2
  • Confused 3
  • Sad 7
ri702bill
Yep, some folks should not play with wrenches.
  • Haha 4
ebinmaine
Oh boy
Bill D
That'll do it.  Did he even put oil back in it??? I'd expect a bigger mess if he did.  Good parts rig for someone.
Edited by Bill D
8ntruck
Yup.  I changed the oil on my MF GC1720 today.  Bit of an access wrassle to get something to turn the oil filter.  Got the new filter on and was just about ready to start pouring the new oil I,  when I remembered I had not put the drain plug back in yet.
Caught it in time, though.
  • Excellent 3
  • Haha 3
mrc
you can't make stuff like this up!
Bill D
Could happen to anyone 🙄
pfrederi
  Never ever happened to me...Not! :P
  • Haha 3
953 nut
Fellow I worked with years ago drained the oil on his Cummings powered Dodge when he got called away to work some overtime. The next morning he dumped three gallons of Mobil One into the engine, about half of it went into the drain pan still in place under the truck, the rest was on the floor.       :hide:
  • Sad 4
Handy Don
Ok, I admit incomplete knowledge, so please school me on why a machine freshly filled with oil and not having its filter iin place didn’t spew oil out the side of the machine. Is the filter only in the pickup side of the oil circulation?
davem1111
 :text-yeahthat: :eusa-think:
Bill D
He changed the oil to a new air based lubricant :D
  • Haha 6
Handy Don
So we don’t really know if there was no oil (i.e. none to spew) or that the no-filter had it sucking air instead of oil.
ri702bill
Methinks it injested a large chunk of his wallet!! :lol:
  • Haha 2
adsm08
Typically the order of flow through a pressurized oil system is pump, filter, crank bearings, cam bearings, lifters/valve train, and then back to the pan.
If the engine was started, with oil in it, it would be EVERYWHERE.
Edited by adsm08
  • Like 4
Handy Don
Thanks. This is what I would have guessed.
I’m thinking that the next time I do an oil change I’ll tape the key to a checklist that I can review before trying to start the engine!
  • Haha 1
adsm08
Not a bad plan.
A few years ago we had an Explorer towed in after a critter got at the main engine harness. In the middle of refilling the magic smoke the customer calls up and asks for us to change the oil. I pulled the filter out (top mounted filter), drain the oil the next time it went up, filled it when it came down, forgot about the filter, and finished the harness about 2 days later.
Fired it up, and it ran for about three seconds before it evacuated all six quarts, out the top, all down the engine, and shut off because of the low oil pressure safety.
  • Sad 3
Handy Don
If you didn’t have a good appreciation of the Explorer’s oil pump before that...
adsm08
Appreciation was not what I had for it in he moment.
I was already rather annoyed because the rodent damage actually caused an electrical fire, and so in addition to everything else, and that harness not being easy to do, everything, including myself, was covered in flame retardant.
  • Haha 2
8ntruck
Not a bad idea - especially for those of us who are getting older and wiser.
Just tonght, I got the MF GC1720 loaded on the trailer.  I shut off the fuel for transport and noticed that the charge light was on for the emergency trailer brake battery.  Not knowing how much it will take to charge it from the truck battery, I unplugged the trailer from the truck.  Got to remember to plug the trailer in before I leave in the morning.  Should leave a note on the tractor key to turn the fuel back on, too.
953 nut
:text-yeahthat:
Many moons ago when I lived in Florida I took a street rod I had just about  finished to an automotive air-conditioning shop to have the system evacuated and filled. There was a bit of a panic situation going on because a customer had just left and the remote from his car had locked the doors of another car which was left running with the driver's door open while the system was being charged. someone had closed the door to allow another car room to back out and didn't reopen it.  This was pre cellphone days and most cars didn't have remote door locks. As luck would have it when my wife showed up to pick me up she knew where the fellow who's remote locked the door worked and we drove over there, borrowed his keys and they opened the door.
From that day forward the AC shop made it their practice to have the windows wide open (not just the door) and a piece of duct tape over the door latch to keep it from closing tight.
