kpinnc
Drag rake
Moparfanforever
Looks like it is still touching the ground even with the lift handle up??
Is it easy to lift with the manual lift??
kpinnc
I adjusted the lift links. It sits about 4 inches off the ground now.
No not really. It's not "60 inch mower deck heavy", but you know it's there for sure. I'm gonna add another hole in the hitch to slide it forward. It has a radiant for rotating to both sides but it won't get used that way here. I think that will lighten the leveraged load a bit on the lift arm.
First test was the gravel driveway. Got rid of the studder bumps on the first pass. So far so good. :thumbs:
  • Excellent 4
  • Heart 1
ebinmaine
Neeeaaat
Moparfanforever
Very nice!!!  👍👍👍👍
