CRF857 1,521 #1 Posted September 14 I have a gallon of Lubriplate FMO 500. Am wondering if it would be good to use on the underside of the mowing deck. Share this post Link to post Share on other sites
peter lena 10,123 #2 Posted September 14 @CRF857 been doing hot sun / lubrication for years , number one thing is totally cleaning out any debris , trapped , grass , personally use a 2 stage soak in , like a chain and cable spray , macs , napa, totally soak down and heat bake , for hours , set up mine for best all day , sun angle , move as needed , then over spray , with the heavier open gear oil , you can easily experiment , I also winter store my decks like this , so that lubrication , becomes imbedded into the metal , was just checking the specs on your lube , possible , but its the lighter initial hot soak in , that sets the foundation , of rust free, pete 1 1 Share this post Link to post Share on other sites
953 nut 70,647 #3 Posted September 14 I used some brush on truck bed liner several years ago (probably 8 or 9) and it has held up well. 1 2 Share this post Link to post Share on other sites
c-series don 12,751 #4 Posted September 15 This has not really answered @CRF857’s question. I’d also like to know the answer to this because I have some of that same stuff that someone gave me. I never really knew what to do with it? Maybe I’ll use it on my decks? 1 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,917 #5 Posted September 15 Can't hurt... expired in 2017, so either use it for bicycles chain oil or put it on the deck and see what happens... 1 3 Share this post Link to post Share on other sites
Ed Kennell 47,939 #6 Posted September 15 I used Lubriplate for years to coat and waterproof carbon steel hydro turbine parts. It sticks and holds up well My main use now is to lube and waterproof bolt threads. 1 1 Share this post Link to post Share on other sites
JoeM 10,318 #7 Posted September 15 I used ez slide a few years ago, held up to half a dozen mowings then needed redone. Just did not have the time to fool with cleaning and pressure washing decks that often. I tried a lot of different treatments none worked well enough make it through a whole season. POR15 was the winner. A lot depends on your grass/soil and of course how many acres you cut and what deck your are using. I cut with a Kubota and it has a high lift deck and it is pretty violent as compared to a WH rear discharge. You can give it a try but you might have trouble if you decide to paint the deck in the future. 1 1 Share this post Link to post Share on other sites
peter lena 10,123 #8 Posted September 15 @CRF857 been rustproofing for years , LEARING AND APPLYING AS I GO , BASE LINE ? lighter , creeping penetrant , serves 2 purposes , ability to get to many UNTOUCHED AREAS , THAT ALSO ACTS AS A CARRIER FOR , LATER APPLICATION . for me its chain and cable lubricant first , any related seaming will show you its trail , let sit / soak for days , then over spray with a open gear type lubricant , heavier sealer type , add hot sun , prop up to that , the longer the better , you know what's GLAIRING ? same basic idea for , PAINT RECOVERY , been doing this for DECADES , this is easy , dare to try , pete 1 Share this post Link to post Share on other sites
lynnmor 9,081 #9 Posted September 15 (edited) 16 hours ago, CRF857 said: I have a gallon of Lubriplate FMO 500. Am wondering if it would be good to use on the underside of the mowing deck. I think that it would hold up very well for about .0025 milliseconds, just like any other oil. It is 30 weight oil that I would use for chain lube in a chainsaw. Edited September 15 by lynnmor 1 Share this post Link to post Share on other sites
