Charger Chris 13 #1 Posted 11 hours ago This is my raider 12 I acquired last month I have the original k301 for it it runs good but for now it has a k341 on it till I decide to restore the tractor. Has the original 10 pinion rear axle to. its a 1969 i added the amp gauge 8 Share this post Link to post Share on other sites
ri702bill 12,799 #2 Posted 3 hours ago Welcome! That is a rugged old worker that you have there.... Just an observation - AG tires are not the better choice for snow plowing. There are special "X" style chains available, but pricey. regular cross link chains tend to fall into the valleys between the cleats and end up not effective, Turf tires, filled with the proper fluid and full complement chains have worked the best for me. And a set of wheel weights make a difference too... 4 1 Share this post Link to post Share on other sites
Achto 32,337 #4 Posted 1 hour ago Nice tractor ! Looks like some one up graded your dash to a newer style. Not a bad choice, the lever throttle & choke are much more user friendly than the push/pull style. 3 Share this post Link to post Share on other sites
Charger Chris 13 #5 Posted 47 minutes ago I plan on using atv tires to plow snow as I’ve done in the past and had great luck with 5 Share this post Link to post Share on other sites
953 nut 68,455 #6 Posted 25 minutes ago Glad you found us. If you have questions please feel free to ask, lots of good knowledgeable people here willing to help. Share this post Link to post Share on other sites
