FLtractor 196 #1 Posted 14 hours ago Afternoon, Currently front tires good condition, rears filled with calcium chloride and are orignally 1966 according previous owner. Will need replace both of those. What’s is thoughts on ordering Un airworthy airplane tires on the 856 in: 5.50x8.00 Front 23x8.50x12 rear compared to buying Turf tractor tires.. how do airplane tires compare? MUCH more durable last LOT longer and worth the price? Cost difference between new tractor and used airplane tires these days? 1 Share this post Link to post Share on other sites
ri702bill 12,782 #2 Posted 14 hours ago Flying Horses??? 1 Share this post Link to post Share on other sites
953 nut 68,430 #3 Posted 13 hours ago Where do you come up with all these off-the-wall thoughts? Stick with turf tires on the rear, the airplane tires are ribbed and offer very little traction. 1 Share this post Link to post Share on other sites
FLtractor 196 #4 Posted 12 hours ago 37 minutes ago, 953 nut said: Where do you come up with all these off-the-wall thoughts? Stick with turf tires on the rear, the airplane tires are ribbed and offer very little traction. Saw someone post about it on social media. Apparently good for wet grass and good for golf courses 1 Share this post Link to post Share on other sites
ebinmaine 80,256 #5 Posted 12 hours ago 1 hour ago, FLtractor said: rears filled with calcium chloride and are orignally 1966 according previous owner. Will need replace both of those Why? Are they currently leaking? Badly cracked? Unless AND until they really are trash I'd be prone to leave them right alone and running. 39 minutes ago, 953 nut said: Stick with turf tires on the rear, the airplane tires are ribbed and offer very little traction. Agreed. And I'd even add to that. ANY moisture (morning dew) is going to be a near zero traction situation. 3 minutes ago, FLtractor said: Saw someone post about it on social media. Apparently good for wet grass and good for golf courses If they're the straight rib airplane tires... I ABSOLUTELY DISAGREE. As far as pricing goes... IF you need wheels, that's where the $$$$ will be. Shipping wheels isn't cheap. BUT if you look in the right place you can find inexpensive trailer (camper or utility) wheels on a few websites. Or... CALL Lincoln at A to Z Tractor in PA and order a good used set of narrow wheels with the correct Wheelhorse backspacing. That's important. 1 2 Share this post Link to post Share on other sites
kpinnc 18,874 #6 Posted 8 hours ago 5 hours ago, FLtractor said: 5.50x8.00 Front Front tires might be ok if they are ribbed. You'd probably be able to run them very low on air pressure if you want. No other real benefit. 1 Share this post Link to post Share on other sites
Retired Wrencher 6,913 #7 Posted 2 hours ago FL: Go to the big show next year and find what you really want. That is my two cents. 1 Share this post Link to post Share on other sites
Achto 32,316 #8 Posted 1 hour ago 11 hours ago, 953 nut said: the airplane tires are ribbed and offer very little traction. Probabley would not be much different than these. https://www.millertire.com/16x6-50-8-rubber-master-rib-4-ply-tire/ 1 Share this post Link to post Share on other sites
ebinmaine 80,256 #9 Posted 1 hour ago 5 minutes ago, Achto said: Probabley would not be much different than these. https://www.millertire.com/16x6-50-8-rubber-master-rib-4-ply-tire/ For the front steering they'd be fine. My cautionary statement above is referring to the rears. I would NOT use a straight ribbed tire for drive traction. 1 Share this post Link to post Share on other sites
Achto 32,316 #10 Posted 1 hour ago 14 minutes ago, ebinmaine said: I would NOT use a straight ribbed tire for drive traction. Agree with you there 1 Share this post Link to post Share on other sites
Pullstart 71,075 #11 Posted 1 hour ago Not sure where in Florida you reside, but around us we have the Lake Michigan sand dunes, especially Silver Lake. I’ve seen quite a few aired down ribbed tires on rear wheel drive vehicles scoot across the sand and quite a clip. Any other surface and I bet there is no benefit… but sand? 1 Share this post Link to post Share on other sites
