the jeep driver
Will Crank, But Will Not Start... 417A with a 17 HP Kohler Engine
the jeep driver
Hello.   My 1985 Wheel Horse 417A with a 17 HP Kohler Engine will turn over, but will not start.  It looks to be getting fuel, I can see gas in the carb...   I did try starting fluid, no start.  I changed the spark plugs, as the old ones were due anyway, and used an inline spark tester to verify spark.  I don't know what to test next.  Any help is appreciated!
ri702bill
Fuel, air, spark, & compression. Ya need all four to rave it run.  The spark - is it a strong blue-white color or pale yellow? Is the timing correct ? - right spark at the wrong time in the cycle equals a no run condition.
Edited by ri702bill
953 nut
This manual should be helpful.
the jeep driver
2 hours ago, ri702bill said:
 The spark - is it a strong blue-white color or plae yellow? Is the timing correct ?
The spark is blue/white, I don't know about the timing.
Thank you.
Ed Kennell
That leaves air and compression.         Has the tractor been sitting for a long time?    Do you have compression?    Possible stuck valves.
peter lena
@the jeep driver  how does the carb throttle plate , easily fit / sit  in its  closed position ? done a lot of  that  detailing , made for instant  starts , now regular on my 3 horses . pete
the jeep driver
No, the tractor was last used 8/22 or 8/23 and it ran fine.  The only difference between that mowing and prior was that I had to mow in the rain for about 20 minutes.  I parked it in the garage, and didn't clean it off as normal... I usually blow all the debris off when finished.  When I wanted to mow on 8/30 it wouldn't start and after messing with it for a while, I borrowed my neighbors mower.
I do not have a manometer for compression testing... I did see on how to make on in the manual 953 posted, haven't had time to make it... I may see if anyone I know has one.
oliver2-44
Most auto supplies loan out compression gauges.
They require a deposit but refund it when you return the gauge.
I'm not that familiar with the Kohler twins, so I checked and best I can tell the Kohler twins DO NOT have a compression release like the single cylinders.
So you should be able to get a good compression reading.
Ed Kennell
I know you said you have a good strong spark, but it surely smells of an electrical problem.   Could the spark plug wires be old and wet enough that they are shorting before the spark gets to the plugs?       Remove the air cleaner and try cranking it in the dark while you look for fire in the plug wires.
Edited by Ed Kennell
the jeep driver
I did this last night, I didn't see anything in the wires.  I haven't had time to do any other tests.
