the jeep driver 29 #1 Posted 22 hours ago Hello. My 1985 Wheel Horse 417A with a 17 HP Kohler Engine will turn over, but will not start. It looks to be getting fuel, I can see gas in the carb... I did try starting fluid, no start. I changed the spark plugs, as the old ones were due anyway, and used an inline spark tester to verify spark. I don't know what to test next. Any help is appreciated! Share this post Link to post Share on other sites
ri702bill 12,767 #2 Posted 19 hours ago (edited) Fuel, air, spark, & compression. Ya need all four to rave it run. The spark - is it a strong blue-white color or pale yellow? Is the timing correct ? - right spark at the wrong time in the cycle equals a no run condition. Edited 10 hours ago by ri702bill Share this post Link to post Share on other sites
953 nut 68,374 #3 Posted 18 hours ago This manual should be helpful. Share this post Link to post Share on other sites
the jeep driver 29 #4 Posted 17 hours ago 2 hours ago, ri702bill said: The spark - is it a strong blue-white color or plae yellow? Is the timing correct ? The spark is blue/white, I don't know about the timing. 1 hour ago, 953 nut said: This manual should be helpful. Thank you. Share this post Link to post Share on other sites
Ed Kennell 46,882 #5 Posted 7 hours ago 9 hours ago, the jeep driver said: The spark is blue/white 14 hours ago, the jeep driver said: I can see gas in the carb. That leaves air and compression. Has the tractor been sitting for a long time? Do you have compression? Possible stuck valves. Share this post Link to post Share on other sites
peter lena 10,000 #6 Posted 6 hours ago @the jeep driver how does the carb throttle plate , easily fit / sit in its closed position ? done a lot of that detailing , made for instant starts , now regular on my 3 horses . pete Share this post Link to post Share on other sites
the jeep driver 29 #7 Posted 1 hour ago 6 hours ago, Ed Kennell said: That leaves air and compression. Has the tractor been sitting for a long time? Do you have compression? Possible stuck valves. No, the tractor was last used 8/22 or 8/23 and it ran fine. The only difference between that mowing and prior was that I had to mow in the rain for about 20 minutes. I parked it in the garage, and didn't clean it off as normal... I usually blow all the debris off when finished. When I wanted to mow on 8/30 it wouldn't start and after messing with it for a while, I borrowed my neighbors mower. I do not have a manometer for compression testing... I did see on how to make on in the manual 953 posted, haven't had time to make it... I may see if anyone I know has one. Share this post Link to post Share on other sites
oliver2-44 11,676 #8 Posted 31 minutes ago Most auto supplies loan out compression gauges. They require a deposit but refund it when you return the gauge. I'm not that familiar with the Kohler twins, so I checked and best I can tell the Kohler twins DO NOT have a compression release like the single cylinders. So you should be able to get a good compression reading. Share this post Link to post Share on other sites
