the jeep driver
Will Crank, But Will Not Start... 417A with a 17 HP Kohler Engine
the jeep driver
Hello.   My 1985 Wheel Horse 417A with a 17 HP Kohler Engine will turn over, but will not start.  It looks to be getting fuel, I can see gas in the carb...   I did try starting fluid, no start.  I changed the spark plugs, as the old ones were due anyway, and used an inline spark tester to verify spark.  I don't know what to test next.  Any help is appreciated!
ri702bill
Fuel, air, spark, & compression. Ya need all four to rave it run.  The spark - is it a strong blue-white color or plae yellow? Is the timing correct ? - right spark at the wrong time in the cycle equals a no run condition.
953 nut
This manual should be helpful.
the jeep driver
The spark is blue/white, I don't know about the timing.
Thank you.
