stevebo-(Moderator) 8,604 #1 Posted October 12, 2009 I have an original k91 kohler out of a 58 rj. I want to sandblast the oil bath housing in prep to repaint it. Does the top part come off the bottom? I know if I blast it I will need to really wash out the parts so no sand gets inside the engine. It looks like it does not come apart?? Thanks- Share this post Link to post Share on other sites
wallfish 19,263 #2 Posted October 12, 2009 The filter section does not separate on the two I have. I would prep it another way. The filter section does separate from the bowl that holds the oil Share this post Link to post Share on other sites
stevebo-(Moderator) 8,604 #3 Posted October 12, 2009 I guess the best way to prep it will be to get all the oil out and then dip it in the E tank... thanks John. Share this post Link to post Share on other sites
VinsRJ 723 #4 Posted October 12, 2009 I would soak in lacquer thinner; 1) it will clean the oil out of it and 2) it will remove the old paint. Light scotch brite pad on the rusted areas and its ready for paint. Share this post Link to post Share on other sites
linen beige 16 #5 Posted October 12, 2009 I would soak in lacquer thinner; 1) it will clean the oil out of it and 2) it will remove the old paint. Light scotch brite pad on the rusted areas and its ready for paint. :scratchead: Share this post Link to post Share on other sites
