fehrrj58 21 #1 Posted August 29 Hi! I'm looking to see if i can get some help with my grandfather’s RJ-58 Serial # 21259. The tractor has a Kohler K91 engine on it. I know this tractor has the original plow as well. I’m just looking to see what I can do to make the tractor last and keep it in good condition. I don’t know much about it. 2 8 Share this post Link to post Share on other sites
953 nut 69,660 #2 Posted August 30 Your grandfather has given you a really nice looking RJ. Don't be afraid to drive the Wheel Horse around and work it if you have any implements for it, that is what they were built to do. To ensure its longevity just maintain the engine oil level and keep the steering lubricated. Was your grandfather a Red Square member? 3 1 Share this post Link to post Share on other sites
parsonsponyz 412 #3 Posted August 30 to Red Square. If you perform normal maintenance on it like the above mentioned that will make it last. 4 Share this post Link to post Share on other sites
rjg854 13,393 #4 Posted August 30 2 your granddad sure did take very nice care of it! I'm certain he'd be happy knowing it's going to live on in the family 3 Share this post Link to post Share on other sites
gwest_ca-(File Mod) 12,494 #5 Posted August 30 Your serial number is high enough it may be a RJ-59 from recorded data. Click on the picture of the manual. 2 1 Share this post Link to post Share on other sites
fehrrj58 21 #6 Posted August 31 (edited) 953 Nut, my dad said my grandfather used to restore the wheel horses at one point and sell them. We have a 312-8 and a 414-12 with a snow plow. My dad got the ‘58 and the my uncle got the ‘61, which he has that as well. Both were born those respected years. I saw it was leaking gas either at the fuel filter by the gas bowl and also at the carb. Any guidance? I did run it, sounds good! Edited August 31 by fehrrj58 2 Share this post Link to post Share on other sites
WHX?? 58,255 #7 Posted August 31 Most likely sediment bowl is leaking. Wipe any gas away and use a bright flash light to try and pinpoint the leak. Once you find it we'll suggest repair/eplace as required and replace the fuel line. 2 1 Share this post Link to post Share on other sites
cafoose 3,870 #9 Posted August 31 9 hours ago, gwest_ca said: Your serial number is high enough it may be a RJ-59 from recorded data. Look at the date code near the shifter boot on the transmission and post it. Something like C9-9 or C10-9 1 1 Share this post Link to post Share on other sites
Retired Wrencher 6,992 #10 Posted August 31 @fehrrj58 As you can see you have lots help here already. Just take your time with your family time pice. We have a great source of manuals here and other info. I would take advantage of this material. And if you can become a supporter for $20 a year this helps post lots of pictures to help with your restoration or problems with the tractor. In the old days, the saying was a picture worth 1000 words. Good luck whatever you do to the tractor. 1 Share this post Link to post Share on other sites
953 nut 69,660 #11 Posted August 31 10 hours ago, fehrrj58 said: I saw it was leaking gas either at the fuel filter by the gas bowl and also at the carb. Any guidance? I did run it, sounds good! Here is a link to a thread that should be helpful, just click on the title in the shaded section and it will open. 1 Share this post Link to post Share on other sites
fehrrj58 21 #12 Posted August 31 Update… here’s a photo of the Kohler engine and a picture of the trans piece 3 Share this post Link to post Share on other sites
cafoose 3,870 #13 Posted August 31 16 minutes ago, fehrrj58 said: picture of the trans piece Looks like June 30,1959 2 1 Share this post Link to post Share on other sites
fehrrj58 21 #14 Posted September 1 So, does that mean it actually is a RJ-59? 1 1 Share this post Link to post Share on other sites
wallfish 20,652 #15 Posted September 1 7 hours ago, fehrrj58 said: So, does that mean it actually is a RJ-59? Yes it was built in 1959 and some of those later 59s came with that type of solid seat. They were all badged RJ-58 so if it still has the factory sticker it would read RJ-58 2 2 Share this post Link to post Share on other sites
fehrrj58 21 #16 Posted September 10 Here’s the photo of the badge 3 Share this post Link to post Share on other sites
WHX?? 58,255 #17 Posted September 10 (edited) 6 minutes ago, fehrrj58 said: Here’s the photo of the badge Wow don't see many originals of those these days. Edited September 10 by WHX?? 1 1 Share this post Link to post Share on other sites
SylvanLakeWH 32,658 #18 Posted September 10 Nice tractor!!! 1 Share this post Link to post Share on other sites
fehrrj58 21 #19 Posted September 11 I was looking to see if I could find a snow plow for this RJ-58 tractor. Is there a specific one I need to search for or can I use other plows made by Wheel Horse? Thanks! 1 Share this post Link to post Share on other sites
953 nut 69,660 #20 Posted September 11 Here is the manual for the snow plow that fits our RJ. Share this post Link to post Share on other sites
Lane Ranger 12,125 #21 Posted September 11 That solid pan seat. (without the earlier 18 hole seat usually on the RJ58) is usually the first sign to me that it might be a 1959 RJ! That is what I thought when I saw your first pictures of your grandfathers RJ. It is a nice one. A classic American piece of machinery that can last for decades if you do maintain it. Share this post Link to post Share on other sites
