fehrrj58
Help with my grandfather’s RJ-58
953 nut
:WRS:
Your grandfather has given you a really nice looking RJ. Don't be afraid to drive the Wheel Horse around and work it if you have any implements for it, that is what they were built to do.   To ensure its longevity just maintain the engine oil level and keep the steering lubricated.
Was your grandfather a Red Square member?
parsonsponyz
 :text-welcomeconfetti: to Red Square.  If you perform normal maintenance on it like the above mentioned that will make it last.
  • Like 4
rjg854
:text-welcomeconfetti:2 :rs:your granddad sure did take very nice care of it! I'm certain he'd be happy knowing it's going to live on in the family  :text-bravo:
gwest_ca
Your serial number is high enough it may be a RJ-59 from recorded data. Click on the picture of the manual.
fehrrj58
Posted (edited)
953 Nut,
my dad said my grandfather used to restore the wheel horses at one point and sell them. We have a 312-8 and a 414-12 with a snow plow. My dad got the ‘58 and the my uncle got the ‘61, which he has that as well. Both were born those respected years. I saw it was leaking gas either at the fuel filter by the gas bowl and also at the carb. Any guidance? I did run it, sounds good!
Edited by fehrrj58
  • Heart 2
WHX??
:WRS:
Most likely sediment bowl is leaking. Wipe any gas away and use a bright flash light to try and pinpoint the leak. Once you find it we'll suggest repair/eplace as required and replace the fuel line.
Pullstart
:text-welcomewave:
cafoose
Look at the date code near the shifter boot on the transmission and post it. Something like C9-9 or C10-9
Retired Wrencher
@fehrrj58        :WRS:    As you can see you have lots help here already. Just take your time with your family time pice. We have a great source of manuals here and other info. I would take advantage of this material. And if you can become a supporter for $20 a year this helps post lots of pictures to help with your restoration or problems with the tractor. In the old days, the saying was a picture worth 1000 words. Good luck whatever you do to the tractor.
953 nut
Here is a link to a thread that should be helpful, just click on the title in the shaded section and it will open.
fehrrj58
Update…
here’s a photo of the Kohler engine and a picture of the trans piece
  • Excellent 3
cafoose
Looks like June 30,1959 :handgestures-thumbupright:
fehrrj58
So, does that mean it actually is a RJ-59?
wallfish
Yes it was built in 1959 and some of those later 59s came with that type of solid seat.
They were all badged RJ-58 so if it still has the factory sticker it would read RJ-58
  • Excellent 2
fehrrj58
Here’s the photo of the badge
  • Excellent 3
WHX??
Wow don't see many originals of those these days.
Edited by WHX??
  • Heart 1
SylvanLakeWH
Nice tractor!!!
fehrrj58
I was looking to see if I could find a snow plow for this RJ-58 tractor. Is there a specific one I need to search for or can I use other plows made by Wheel Horse?
Thanks!
953 nut
Here is the manual for the snow plow that fits our RJ.
Lane Ranger
That solid pan seat. (without the earlier 18 hole seat usually on the RJ58) is usually the first sign to me that it might be a 1959 RJ!
That is what I thought when I saw your first pictures of your grandfathers RJ.  It is a nice one.  A classic American piece of machinery that can last for decades if you do maintain it.
