BPEisenhower
Buyers Remorse.....
BPEisenhower
Hello Horse fans! Decent weather for outdoor activities and decided to jump into fixing the 520. After looking at the wiring diagram, burned connectors and the spaghetti of extra wiring, I did the wrong thing the right way. I ran power straight to the coil and touched a hot wire to the starter. Runs like a clock. I figured since it was running, it wouldn't hurt to see what happens. After a short run around the yard, the 520 has plenty of power, steers effortlessly and mows beautiful. However, the 60 inch deck doesn't raise very high and gauge wheels roll the ground constantly, motion lever must be pushed down past a detent for forward or reverse. Forget about turning, front tires slide uphill and downhill. I'm thinking about putting motor, deck and front axle either under another C195 or modifying my great grandfather's that I grew up on. Either way, I shouldn't have brought it home
Bill D
I've fixed up way worse.  Wiring is the biggest issue, but not insurmountable.  New tires, build a foot control, adjust the lift linkage and you may just like it.  How many hours on it?  It really does look pretty good in the photos.
953 nut
Looks much too nice to be cannibalized, that is what other brands are for.  You will end up with a boneyard of otherwise nice 520 parts.
Cannibalize Cartoons and Comics - funny pictures from CartoonStock
  • Haha 3
  • Sad 1
lynnmor
The motion lever is operating correctly, get used to it.  The deck needs to be adjusted per the deck owners manual.
JoeM
The 520 I had would slide too on a decent side slope. I had to raise the deck to put more weight on the front tires when turning sometimes. I added 40 pound of wheel weight on the front tires and it did help.
The OE tires are terrible and I was going to get something better but moved on to a xi machine for mowing.
Might pay you to look and see if the deck is hitting the stops under the foot boards when raised. They don't have a lot of raise room to begin with so every inch counts. Taller rear tires might help get you some more raise room.
BPEisenhower
1474 hours. Was used to mow 3 acres weekly and clear a 50 foot driveway with the blower. In decent shape for its age.
c-series don
Sliding the bolt up to the top of the slot inside the blue circle will get the back wheels of the deck off the ground when it’s lifted.
Mike'sHorseBarn
I wouldn't chop that one up. You could sell it to another member here and then take that money to buy what you're looking for.
sjoemie himself
If that tractor was located in the Netherlands I would probably have to pay $1500 to $2000 to take her home :huh:
BPEisenhower
Thank you for the advice! It does clear the ground finally. Still working on wiring issues since so many extra wires added and spliced. None of the gauges work and power is getting to them but I think they are going to need replacement. All the red warning lights work but no gauges, however power is getting to them. Have to order new relays since all I get is clicking
702854boy
How come this thread ended up in the supporters only section?
