Krice58
Crank Pulley Removal/Engine Machine Shop Locations
Krice58
I’m sure this is on here somewhere just hoping for some tips. Trying to remove crankshaft pulley off a K341, took out the set screws and it won’t budge. What are we using to remove these? Jaw pullers? Gear pullers? PB Blaster and prayers? Also anyone have any suggestions for machine shops in the NE Ohio, W PA area, or  would any old machine shop that does small block chevys and fords be able to do a k series? Like to have this block honed, maybe bored, valve seats maybe and the crank looked at. Thanks in advance!
ineedanother
Penetrating oil. Give it some time, it shouldn't take too much. I've "lightly" tapped them in with a section of pipe over the shaft but put a flat pry bar behind first to retain that space between the pulley and block. It can tolerate light shocks to break the brown weld if there is any.
  • Like 4
Krice58
Finally let loose.
  • Excellent 7
squonk
Can't believe no one mentioned a harmonic balancer puller! :confusion-confused:
You're fortunate to get it off without damaging it.
OEMTOOLS 25053 Heavy Duty Harmonic Balancer Puller Set, Engine Repair and Maintenance, Durable Alloy Steel Construction, A...
  • Like 4
  • Excellent 5
ebinmaine
I've used a good quality steering wheel puller too.
10 hours ago, Krice58 said:
PB Blaster
Everyone has their favorites on penetrating oil but this product has been proven over and over to be inferior to pretty much everything else.
Krice58
I have one of these that I use on the flywheels. Tried using it on this but I didn’t have long enough bolts on hand that fit.
oldlineman
I like Kroil oil, a little pricy but you get what you pay for and don't over do it, what drops on the floor has no effect on what you are doing.
  • Like 4
Krice58
I usually don’t use PB, just had a can laying around. What do you recommend? I’ve used Seafoam Deep Creep and some CRC stuff in the past that seemed to work well. I don’t have Kroil money.
Krice58
I’ve only used Kroil a handful of times. Good stuff, just don’t do enough work to warrant the cost and I end of losing the can half the time.
squonk
Longer bolts are easier and cheaper to get than another pulley
sqrlgtr
I would like to have the money Ive spent on inferior products because I couldn't find any Kroil local. I always have a can or two on hand now aerosol and liquid. I just order it off innerweb now when I start getting low.
ebinmaine
I love Kroil but refuse to buy it because of the local availability and inflated price.
I've tried many. The two that seem to work best for me are:
good old fashioned original formula Liquid Wrench
and the WD-40 Specialist Penetrating Oil.
Note that is NOT the standard WD40 Traditional Formula which is NOT a penetrating oil.
I've been meaning to try a 50/50 of ATF & acetone but keep forgetting.
Handy Don
I am satisfied with Liquid Wrench and smile that it constantly seeps out of the little dispenser bottles I decant the big bottle into. Just doin’ its job, right!?
  • Haha 2
Krice58
Definitely gonna get some for next time.
Krice58
I just realized this pulley is smaller in diameter than my original. Both K341 71128 but mine is off an auto and the other engine is off an 8 speed. Looks like the part number I need is 7443 and I got the 7466. Anyone got a 7443 they’d be willing to part with? Looks like diameter of the one I need is 5 1/4. I guess the autos have the bigger pulley? The 8 speed one is like 4 inches.
stevasaurus
I'm a believer with the ATF & Acetone.  Works great. :occasion-xmas:
oldlineman
I agree, I have used this mix over some years and it seems to work, it will separate over time but just needs a good shake to get it back together.:)
Racinbob
I'm not really 'sold' on anything and experiment with various products. This stuff here seems to work quite well but it's kinda pricy. I'd rather apply it to just the area needed so I released the pressure and poured it in a squirt bottle.
Cre-Oil Cre-Oil 11 oz. Penetrating Oil
953 nut
I probably have a half dozen "metrical cure" penetrants on the shelf that have been recommended as being THE BEST EVER on here and I always go back to Liquid Wrench, it works,         :twocents-02cents:
  • Excellent 2
Krice58
Still have to clean these up. But I think I have two useable blocks. Just gotta find a machine shop. Should I just leave the valve guides alone?
Edited by Krice58
Retired Wrencher
Well guys you were taking pullers for the crank side. I made this one from an existing puller  that I had it is really bent one time when I was trying to get a drive hub off. The seal was leaking bad. It actually broke the snap ring inside the transmission. They had to recut the grove for a new snap ring. So now I use it to remove the crank pulley. It works every time rusted crusted doesn’t matter. It pulls it off so easy. This is a heavy duty puller from a set that I have. I’ve seen some engines were badly rusted caked with whatever I thought I’d never get it off, but I hooked it up sprayed it down. Came off like butter. Just sharing my two cents..
Edited by Retired Wrencher
