Retired Wrencher 6,986 #1 Posted August 20 I have this B-60 with a Start/Gen engine in it = not by me. I would like to get an original engine for this. This would be my show putter, reason is I’m trying to preserve the 856 I have. Having a hard time finding one around here. I really don’t wanna put a harbor freight engine in it. I know some people like them and some people don’t. Any thoughts are welcome or someone here has one 100 miles or less. I’d be willing to pick it up. These are cool little tractors. With a big gas tank. I’m thinking you could drive multiple days on one tank at the shows. I’ve only seen a couple in my time. Thanks for any thought`s. Share this post Link to post Share on other sites
Achto 32,687 #2 Posted August 20 Are you planning are transferring the engine from the B-60 to your 856? If not, then I would run it like it is. 1 1 Share this post Link to post Share on other sites
ebinmaine 80,694 #3 Posted August 20 48 minutes ago, Achto said: Are you planning are transferring the engine from the B-60 to your 856? If not, then I would run it like it is. He wants to have the original 7 HP pull start engine in there. How difficult would it be to make an 8 HP electric start into a pull start? Share this post Link to post Share on other sites
ri702bill 13,050 #4 Posted August 20 (edited) Hmmm... I'm not too sure that adding a yank start to a 7 or 8 HP Kohler with a dead weight S/G as you pull the rope is a great idea. One of the dis-advantages with the pull start style the contortions you do to clutch it as you attempt to start it. (provided you have the rope handle facing to the rear). A lot have the rope handle facing the grille - you best make absolutely sure the Unidrive is not in gear! If what you already have works, charges, doesn't leak or smoke... just run it and criuse the Big Show next year to find what you want.... Edited August 20 by ri702bill 3 Share this post Link to post Share on other sites
Achto 32,687 #5 Posted August 20 16 minutes ago, ebinmaine said: How difficult would it be to make an 8 HP electric start into a pull start? Recoil & cup Fly wheel Magneto Might have to drill holes in the fan shroud for the recoil. 1 Share this post Link to post Share on other sites
ebinmaine 80,694 #6 Posted August 20 Just now, ri702bill said: One of the dis-advantages with the pull start style the contortions you do to clutch it as you attempt to start it. (provided you have the rope handle facing to the rear). That's an excellent point. 1 hour ago, Retired Wrencher said: original engine Gary are you OK with having a tractor that likely forces you to go through all the motions of the starting process while OFF the seat, then climb on a running rig? Why even consider a harbor fr.. engine at all? You have a great Kohler engine there now. Share this post Link to post Share on other sites
Achto 32,687 #7 Posted August 20 3 minutes ago, ri702bill said: A lot have the rope handle facing the grille - you best make absolutely sure the Unidrive is not in gear! I have all of mine facing forward. Also have a strict starting procedure that I follow. One of the steps is to lock the parking brake, if it has one. 1 1 Share this post Link to post Share on other sites
953 nut 69,283 #8 Posted August 20 19 minutes ago, ebinmaine said: He wants to have the original 7 HP pull start engine in there. How difficult would it be to make an 8 HP electric start into a pull start? You would need the non-ring gear flywheel, magneto and the appropriate sheet metal. There would be no battery, lighting or lighter (smoking is bad for you anyway). In my opinion we are all getting older and pushing a button is better than yanking a rope. K-181S is shown as the proper OME engine for a B-80. That is an electric start eight horse power Kohler, that is the way to go. Most people wouldn't know the deference and you could always say the B-80 decals are on backorder. 2 Share this post Link to post Share on other sites
ebinmaine 80,694 #9 Posted August 20 7 minutes ago, 953 nut said: K-181S is shown as the proper OME engine for a B-80. That is an electric start eight horse power Kohler, that is the way to go. I agree 1 Share this post Link to post Share on other sites
Retired Wrencher 6,986 #10 Posted August 20 (edited) 7 hours ago, Achto said: Are you planning are transferring the engine from the B-60 to your 856? If not, then I would run it like it is. It was said that Sparky wants the engine if I can find a yank engine for it. Time will tell thanks for the reply. But on the other hand for the first time, I will be going to the big show next summer. It always interfered with what I do with time with my brother and friends. So My wife and I will be driving down. Maybe I’ll get lucky and find one down there. Thanks for the reply. AChto. Edited August 20 by Retired Wrencher 2 Share this post Link to post Share on other sites
Retired Wrencher 6,986 #11 Posted August 20 6 hours ago, 953 nut said: You would need the non-ring gear flywheel, magneto and the appropriate sheet metal. There would be no battery, lighting or lighter (smoking is bad for you anyway). In my opinion we are all getting older and pushing a button is better than yanking a rope. K-181S is shown as the proper OME engine for a B-80. That is an electric start eight horse power Kohler, that is the way to go. Most people wouldn't know the deference and you could always say the B-80 decals are on backorder. I agree with that Richard. Very easy to make the six into an eight with a black magic marker 5 feet away. You’ll never know the difference. I will keep that in mind. But like I said in my last post, I’m hoping I can find something down at the big show. I’m finally going to make it. 3 Share this post Link to post Share on other sites
Retired Wrencher 6,986 #12 Posted August 20 (edited) 6 hours ago, ebinmaine said: That's an excellent point. Gary are you OK with having a tractor that likely forces you to go through all the motions of the starting process while OFF the seat, then climb on a running rig? Why even consider a harbor fr.. engine at all? You have a great Kohler engine there now. Thanks bud. But I got the rest of the year into the spring no hurry. It’s like I said another post here. I’m finally gonna go to the big show next summer. So I hope I get lucky down there and find something. Edited August 20 by Retired Wrencher 1 Share this post Link to post Share on other sites
ebinmaine 80,694 #13 Posted August 20 10 minutes ago, Retired Wrencher said: the big show You'll almost definitely find something there. 1 Share this post Link to post Share on other sites
Retired Wrencher 6,986 #14 Posted August 20 1 minute ago, ebinmaine said: You'll almost definitely find something there. A couple years ago had Zagray there was a person who had a B 60 the guys were picking on me. They thought I was too old to yank it over. It was pretty easy. 3 Share this post Link to post Share on other sites
TonyToro Jr. 2,539 #15 Posted August 21 On 8/20/2026 at 2:05 PM, Retired Wrencher said: A couple years ago had Zagray there was a person who had a B 60 the guys were picking on me. They thought I was too old to yank it over. It was pretty easy. I remember that! It was my tractor. It really doesn’t take much to pull over these little engines. Share this post Link to post Share on other sites
Retired Wrencher 6,986 #16 Posted August 22 Thanks for letting me pull it over Tony. Next time I will ask for permissionI don’t know why I’ve always liked that model. I only seen a handful of them in my time. Thanks for the reply. The next time I’ll ask for permission? Share this post Link to post Share on other sites
Sparky-(Admin) 26,358 #17 Posted August 23 @Retired Wrencher You going to share with these guys the motor you picked up this weekend? 2 Share this post Link to post Share on other sites
Retired Wrencher 6,986 #18 Posted August 24 16 hours ago, Sparky said: @Retired Wrencher You going to share with these guys the motor you picked up this weekend? Opps I will have to get to that Mike. 1 Share this post Link to post Share on other sites
Retired Wrencher 6,986 #20 Posted August 24 3 hours ago, squonk said: I did hear it run Mike. Share this post Link to post Share on other sites
