John c 212 #1 Posted Saturday at 01:49 PM This week I had occasion to work my little "8" 4speed a bit harder that just puttering around the yard. I noticed with actual load on the engine it would sputter and want to cut out. The load used was a 48" core aerator with 200# of lead and 240# of me, on level ground was fine, pulling up a grade it would act up, at first I thought it was low on fuel because that what it sounded like. Can an ignition issues cause this type of behavior ? Share this post Link to post Share on other sites
rmaynard 17,489 #2 Posted Saturday at 02:51 PM Many probables here. I would check the fuel delivery system from the fuel cap vent, to the screen in the tank shutoff valve, to old deteriorating fuel lines to a weak fuel pump, to a dirty or maladjusted carburetor. I would clean and re-gap the points, and replace the condenser. Replace the spark plug and ignition wire. It could be any of the above. I don't think that the weight would be the issue. I have pulled me (235lb) and trailers full of stone with an 8 hp. 4 1 Share this post Link to post Share on other sites
ebinmaine 79,981 #3 Posted Saturday at 03:09 PM 13 minutes ago, rmaynard said: Many probables here Agreed. 13 minutes ago, rmaynard said: I don't think that the weight would be the issue. I have pulled me (235lb) and trailers full of stone with an 8 hp. Certainly shouldn't be. I've pulled a total pushing 1500 - 1800 lbs up outta our forest using an 8 HP. Almost all tilted. Couple wicked uphills. 1 hour ago, John c said: on level ground was fine, pulling up a grade it would act up, The "up" there is a hint but could be because of the tilt back causing fuel starvation or because of the extra work being done temporarily. Share this post Link to post Share on other sites
John c 212 #4 Posted Saturday at 03:22 PM My reason for listing weights was to give some indication of the load involved, not much I know, but more than a simple joy ride. EB I thought the same thing, low fuel, but there was plenty, I even added more to be sure. Hoses, filters, screens are all new, carb and pump have been cleaned and rebuilt, the fuel was clean, fresh, non E 90 octane. The ignition parts are all what the machine had in it when I got it. Does this behavior sound like something points, condenser wear would cause ? Share this post Link to post Share on other sites
8ntruck 9,141 #5 Posted Saturday at 03:26 PM Not sure why, but my initial thought was the condenser. Share this post Link to post Share on other sites
ebinmaine 79,981 #6 Posted Saturday at 03:28 PM 5 minutes ago, John c said: Does this behavior sound like something points, condenser wear would cause ? 1 minute ago, 8ntruck said: Not sure why, but my initial thought was the condenser. Possible. Can you CLEAN the points? Then retry? 1 Share this post Link to post Share on other sites
John c 212 #7 Posted Saturday at 04:26 PM Can you CLEAN the points? Then retry? I can, I think I have a new condenser too, I'll report back on how it turns out, thanks guys 1 Share this post Link to post Share on other sites
sqrlgtr 3,559 #8 Posted Saturday at 09:13 PM Those K181 8's punch way above their weight class and a well tuned one will surprise you at the amount of work they will do. 1 Share this post Link to post Share on other sites
ebinmaine 79,981 #9 Posted Saturday at 09:16 PM 2 minutes ago, sqrlgtr said: Those K181 8's punch way above their weight class and a well tuned one will surprise you at the amount of work they will do. My first Wheelhorse. 1974 B80. Tugging a tree. 1 Share this post Link to post Share on other sites
953 nut 67,971 #10 Posted Sunday at 01:29 PM 22 hours ago, John c said: My reason for listing weights was to give some indication of the load involved, not much I know, but more than a simple joy ride. EB I thought the same thing, low fuel, but there was plenty, I even added more to be sure. Hoses, filters, screens are all new, carb and pump have been cleaned and rebuilt, the fuel was clean, fresh, non E 90 octane. The ignition parts are all what the machine had in it when I got it. Does this behavior sound like something points, condenser wear would cause ? Cleaning the ignition points and replacing the spark plug should always be the first step in correcting poor running conditions. Easy way to rule out the condenser is to temporarily disconnect it for testing, if conditions improve then replace it, if not then look elsewhere. 5 Share this post Link to post Share on other sites
John c 212 #11 Posted 6 hours ago Cleaning the points and replacing the condenser cleared it right up, running strong again now, thanks 2 2 Share this post Link to post Share on other sites
