John c
ignition or carb ?
John c
This week I had occasion to work my little "8" 4speed a bit harder that just puttering around the yard. I noticed with actual load on the engine it would sputter and want to cut out. The load used was a 48" core aerator with 200# of lead and 240# of me, on level ground was fine, pulling up a grade it would act up, at first I thought it was low on fuel because that what it sounded like. Can an ignition issues cause this type of behavior ?
rmaynard
Many probables here. I would check the fuel delivery system from the fuel cap vent, to the screen in the tank shutoff valve, to old deteriorating fuel lines to a weak fuel pump, to a dirty or maladjusted carburetor.  I would clean and re-gap the points, and replace the condenser. Replace the spark plug and ignition wire. It could be any of the above. I don't think that the weight would be the issue. I have pulled me (235lb) and trailers full of stone with an 8 hp.
ebinmaine
13 minutes ago, rmaynard said:
Many probables here
Agreed.
Certainly shouldn't be.  I've pulled a total pushing 1500 - 1800 lbs up outta our forest using an 8 HP.
Almost all tilted. Couple wicked uphills.
The "up" there is a hint but could be because of the tilt back causing fuel starvation or because of the extra work being done temporarily.
John c
My reason for listing weights was to give some indication of the load involved, not much I know, but more than a simple joy ride. EB I thought the same thing, low fuel, but there was plenty, I even added more to be sure. Hoses, filters, screens are all new, carb and pump have been cleaned and rebuilt, the fuel was clean, fresh, non E 90 octane. The ignition parts are all what the machine had in it when I got it.
Does this behavior sound like something points, condenser wear would cause ?
8ntruck
Not sure why, but my initial thought was the condenser.
ebinmaine
Possible.
Can you CLEAN  the points? Then retry?
